Hello Ken,
Attached
Uri
sg_logfile_20160204162916.txt (18.6 KB)
Sorry, the log file will not be of much use in these case… we need the sgf (sequence file) or sgp (profile file) in order to see what’s happening or how to reproduce the issue.
Ken, Sorry you asked for the SGP or SGF. The error message appears before SGP opens and is showing in the above Log file I sent
Uri
Right, I understand that… it would just be very helpful to look at “Prostar with ASCOM.sgp”
Ken,
Link to he SGP profile file
Uri
Thanks. I’ll take a look.
sgp link is as follows:
Thnx
Roger
Just installed 2.5.0.9. Went from 2.5.0.7.
All my User Profiles and Equipment Profiles went poof. Just gone.
However, I discovered that all my equipment settings in the Sequences are all still there, so it is easy to ‘Save Sequence as Profile’ to recreate them from the sequences. The sequences all seem to be unchanged.
Ken, this may be how you intend for it to operate at this stage of evolution. Fine with me.
I doubt they are gone. If you wouldn’t mind zipping the actual sgp files up we can take a look at why they are not displaying properly. The path to them can be found in the options dialog.
I just figured out why they do not show up. This is a new pc for my obs as of last summer, and had Win 8.1 installed.
A couple of months ago I accepted Microsoft’s kind offer to upgrade me for free to Win 10. Great.
But then not so great. My 3 focusers would not work under Win 10. Probably needed a reinstall under Win 10.
So I reverted back to Win 8.1. These changes in os produced a 2nd user under C:\Users: I then had Jerry and Jerry_000. The old formats were in Jerry_000 and the new ones are going into Jerry. I copied them over and now they show up. The .9 release apparently reset my path to the sgp files.
Hi Ken
I am sure you know best , but I I find I can image from 450mm to 3m with the default catalogues and all
works fine
Keep up the hard work
Harry
I also have had perfect results with Astrometry.Net at 2.4 m with the default catalogs.
Actually I don’t know best… I am just following recommendations from the developer.
This issue has been addressed in 2.5.0.10
I am very pleased to report that version 2.5.0.9 ran wonderfully well for me last night, a total of 6 hours with 3 targets.
And the PHD2 guiding with the new release worked perfectly.
Several issues we have been dealing with have been fixed, or at least worked perfectly for me last night, including:
The only remaining issue that is still there for me is that the requested Park the telescope and close the dome do not occur. I see commands in the log to Park:
[2/5/2016 5:57:07 AM] [DEBUG] [Sequence Thread] Stop telescope tracking…
[2/5/2016 5:57:07 AM] [DEBUG] [Sequence Thread] ASCOM Telescope: Setting tracking state to False
[2/5/2016 5:57:08 AM] [DEBUG] [Sequence Thread] Parking telescope…
[2/5/2016 5:57:08 AM] [DEBUG] [Sequence Thread] ASCOM Telescope: Park message received.
[2/5/2016 5:57:08 AM] [DEBUG] [Sequence Thread] ASCOM Telescope: Sending park…
and the telescope does stop tracking, but never parks.
The message ‘Parking telescope’ shows on the status bar for 5+ minutes, then shifts to run finished.
Prior reports I made that SGP hung at the ‘Parking telescope’ message may in fact have not been hangs but just my impatience to wait the 5+ minutes for SGP to quit trying to park the scope.
The Gemini2 log shows repeated attempts to park, but the mount never moves from where it stopped tracking:
Certainly possible… we do have a 5 minute timeout here. A couple questions:
Sequence always fails to park the mount.
Last night I tried unchecking the option to stop tracking, and left park mount checked. No change.
Do you want another set of logs?
Unfortunately I don’t think that will be super helpful. We know that SGPro is sending the command to your mount. I see it in your mount logs, but I am not versed enough in “Gemini” to understand the failure. Something about invalid Azimuth?
05:57:08.157 IT:AtPark.Get TID:7 [Enter] False
05:57:08.157 IT:Park TID:7 [Enter]
05:57:08.157 DoPark TID:7 [Enter] SlewAltAz
05:57:08.157 Transmitting commands TID:9 [2]: :Sz287.010000#:ONPC Object#:Sa-37.150000#:MA#
05:57:08.157 TransmitUDP packet#, cmd TID:9 [0]: 163925, :Sz287.010000#:ONPC Object#:Sa-37.150000#:MA#
05:57:08.157 Done transmitting TID:9 [2]:
05:57:08.157 Ethernet wait for respons TID:9 [0]: :Sz287.010000
05:57:08.158 getUDPCommandResult recei TID:9 [2]: 102No object selected.#
05:57:08.158 Ethernet Received TID:9 [0]: :Sz287.010000
05:57:08.158 Ethernet received: TID:9 [0]: :Sz287.010000, 1
05:57:08.158 Ethernet wait for respons TID:9 [0]: :Sa-37.150000
05:57:08.158 Ethernet Received TID:9 [0]: :Sa-37.150000
05:57:08.158 Ethernet received: TID:9 [0]: :Sa-37.150000, 0
05:57:08.158 Ethernet wait for respons TID:9 [0]: :MA
05:57:08.158 Ethernet Received TID:9 [0]: :MA
05:57:08.158 Ethernet received: TID:9 [0]: :MA, 2No object selected.
05:57:08.158 _UpdatePolledVariablesUDP TID:9 [Enter]
05:57:08.158 TransmitUDP packet#, cmd TID:9 [0]: 163926,
05:57:08.158 Az value is invalid TID:7 [Error]:
05:57:08.158 IT:Park TID:7 [Exit]
What do the Gemini driver support people say? They should be in a much better position to interpret their logs.
Ken,
I have been using 2.5.0.7, but now I want to upgrade to 2.5.0.12. If I understand correctly, I need to go into all of my existing sequences and profiles and find the settings that used to be global and set them in every sequence and profile… right?
Can you tell me specifically what settings I need to change (the full list)? I want to make sure I do not overlook anything.
Andy
