Hi, I have this very frustrating problem, using sbig camera, Starizona autofocus and Gemini G11 mount with ascom driver, Here’s what happens
I set up a sequence (tonight was M33) Its an sbig STT 8300 m camera, so I set RGBL events, 5 exposures each of 2 mins. I use the frame and mosaic wizard to create the targets initially. I save the sequence. All goes well to start - I click ‘slew now’, ‘centre now’ - it plate solves, the autofocus runs, I start Phd and let it calibrate and start to guide. Once phd is settled, I click ‘run sequence’.
The R event runs fine, filter changes, autofocus runs and here’s the problem, at the end of autofocus i get ‘sequence complete’ ‘dismiss’. - but there are three more events selected in the sequence.
So I have tried lots of things - I don’t have any end of sequence actions set, so I dismiss, dismiss with run end of seq actions ticked, reset the progress of the sequence etc etc, but nothing works until eventually I am about to give up, reset the sequence progress one more time and it resumes.
You can guess though that at the end of the ‘G’ event, the same thing repeats - aoutofocus runs, then ‘sequence complete’
I have looked carefully at the equipment profile and the control panel, I can’t see anything wrong. All the target events are selected.
Unfortunately I don’t know what makes it resume - I repeatedly try ‘reset sequence progress’ ’ resume’, deselect the events, reselect them etc.
sorry for long post, any help appreciated.
Paul
