In search of the perfect flat… Hoping someone can give me some insight into the problem I’m having. A search turned up info on adjusting the brightness per filter, but that hasn’t helped with the issue.
When running the flat panel wizard, with everything connected and no issues whatsoever running light frames, the wizard will turn on the panel for a split second and then right back off. Even with the panel brightness set to max.
Log Files
Thanks in advance!
