HI,
I have a simple question about the settings SGP uses for Alnitak Flatbox communications from SGP.
I have created a new updated Alnitak emulation box which considerably extends the features of the true Alnitak box via a second API. I have been testing it with my own program at 38,400 BAUD and was all ready to try it out from SGP since everything appears to be working as designed.
It appears that SGP ignores the settings applied to the COM Port in the Windows Device Manager and always overrides the connection to 9600 BAUD. Is that correct?
When I force my device to run at 9600 BAUD by also overriding the Windows Device Manager settings in my own code, the new device works perfectly with SGP. However, during device set-up prior to connection with SGP, a considerable amount of data is sent back and forth between the device and my own configuration utility program. Because of that, I would prefer to always have the device run at higher speeds.
Is there any way to allow SGP to use the Windows assigned COM Port settings in the Device Manager when talking to an emulated Alnitak Flatbox?
John
