Another Crash on Save - lost Complete Sequence and a clear night
I had just tweaked a sequence and was ready to start imaging when I made the mistake of saving it and got the Type ‘Newtonsoft.Json.Linq.JArray’ in Assembly 'Newtonsoft.Json.Version=4.5.0.0. Culture =neutral.PublicKeyToken=30ad4fe6b2a6aeed is not marked as serializable error on saving a Sequence error.
I tried to reload the sequence and got “End of stream encountered before parsing was complete” It was too late to rebuild it from scratch so lost the night. Would sure like to get this fixed - and why aren’t these errors trapped? they are extremely disruptive.
Wayne
And also just found out it trashed the profile it was based on also. Completely disappeared.
Here’s a drop box link to a log file that appears to end right after the flats calibration wizard completed but nothing about the crash. Also the M15 sgf file that no longer loads for me
Wayne - the logs appear to be quite a few issues reading and writing files, - looks like something is corrupting?
I’m guessing there is something unique about this as it would have popped up more frequently as an issue (I have never seen this issue myself). Does this occur on simple all sequences/profiles or just select ones? (I did a forum search; some crash issues were reported when saving sequences with flats.) Maybe worth looking at those to see if you have the same issue or get closer to the problem.
I had this happen to me quite a few times… I have a new strategy of backing up my sequences and profiles to a completely different folder. Secondly, when SGP crashes, I just let it sit and rush to file manager, find the sequence under Documents/Sequence Generator Pro and copy the sequence to my safe folder. This way, I am able to rescue my sequences. If you shut down SGP and allow it to restart, it erases your sequences… the sequence remains in tact during the crash…
It all seems to be happening around flats. When I do a flats calibration and try to save it, or more recently, when I entered my Alnitak Flip Flat brightness levels in the Sequence Control Panel, I errored out when I tried to save it.
Lol! I’ll try that
That might explain why I have not seen similar issues. My flat sequences are manual, using a standard sequence pointing the scope to the obsy wall.
