I have installed SGP on a Win7 64bit PC, and installed the astrometry.net local plate solver using ansvr-setup 0.15.3.exe.
On a reboot everything starts up OK, and I have set up SGP to point to my local http://127.0.0.1:8080/api.
TCP view confirms that perl.exe is listening on post 8080 correctly.
When I perform a blind solve on an image it fails and perl.exe is no longer in the TCP view list, and ansvr settings does not work.
The watch ansvr log is as follows:
[2015-09-27 15:48:15] ansvr 0.15 start
[2015-09-27 15:48:15] loading config from /var/tmp/platesolve/config
[2015-09-27 15:48:15] read port 8080 from reg
[2015-09-27 15:48:15] using scale error override value 5 percent
[2015-09-27 15:48:15] using downsample 2
[2015-09-27 15:48:15] solution coordinates will use epoch J2000
[2015-09-27 15:48:15] saving config to /var/tmp/platesolve/config
[2015-09-27 15:48:15] [Server /opt/ansvr/ansvr accepting clients on port 8080]
[2015-09-27 15:50:26] [Connect from 127.0.0.1]
[2015-09-27 15:50:26] POST /api/login HTTP/1.1
1 [main] perl 4488 C:\Users\Astro\AppData\Local\cygwin_ansvr\bin\perl.exe:
*** fatal error - NtCreateEvent(lock): 0xC0000058
Waiting for data… (interrupt to abort)
I have tried disabling the Windows Firewall but it doesn’t help.
I must have done something wrong, so any help would be apprciated.
Thanks.
