Forgive me… I’m a total newbie to SGP. I don’t have Internet Access where I image, so I thought: “ah ha, local plate solving is for me.” But the version of SGP I’m using, (the latest, I believe), doesn’t have any settings for astrometry.net that let me tell it there’s a local server. Is that because SGP knows enough to look for it? Am I doing something foolish?
I jumped into local plate solving also with Astronomy.net, and followed the online instructions. Astronomy.net is installed and ansvr is working.
There is one point where I am bumped: in SGPRo, I don’t see the “Other” button on the Plate solving tab, so I cannot enter the local address as mentioned in step 14. I am using SGpro 2.4.1. Any ideas ?
Port numbers 8080-8081 were not available and so I re-installed to port 8082 which was.
After the install I checked via the cmd prompt netstat -n -a -b to check my ports again only to find port 8082 used by LMS.exe.I canßt seem to get a port working without some other process taking over.
Here is a copz of my log file.
You’re on the right track. On Windows 7 or later you can try any port number below 49152; on Windows XP you can try any port outside the range 1025–5000. You are bound to find one that is not in use eventually, just keep trying.
That makes me think there is something else preventing it. The most likely candidate would be Windows Firewall. You should try temporarily disabling Windows Firewall to rule that out.
I’m having the same issue. My log file is identical to Singlin1 except my port is 8080. I’ve also tried a number of different ports and I have disabled the windows firewall. Any other ideas?
I have two telescopes and their field of view are as follows:
ED80 with 0.8 reducer with Atik 383L = 2.17 x 1.61
Skywatcher Quattro 10" with Atik 383L = 1.04 x 0.77
My widest index is 4212 (2 to 2.83 degrees)
Mz Narrowest index is 4205 (20% of 0.77=15.4 arcmin)
Hi Simon,
This looks like a problem I had some time ago.
If you goto the plate solve tab click on other and check the End Path
I think yours will be http://127.0.0.1:8082/api/config
Try deleting the /config Dropbox - Error
Nigel
When you observe the plate solving, does it try 3 times? Can you watch the error get smaller with each attempt, or does the error stay the same?
What mount are you using? 3 attempts may not be enough to get to your desired error of 50px. It also might depend on the mechanical accurracy of the mount.
