I have a Feathertouch focuser with the focuser boss system. Works manually and can be seen in the SGP equipment profile manager. The fine and course controls both work.
However, the RUN control is always greyed out on the focus control panel.
Any ideas on how to get it to turn on the run button.
FocusLynx. Of course FocusLynx will be either “FocusLynx 1” or “FocusLynx 2” with the focuser boss as it can have two focusers attached. It would be “FocusLynx 1” if you have only one focuser attached. Clicking the setup should bring up the FocusLynx Commander focuser setup where you would pick the serial port number.
I have found that, unlike some things (the Alnitak Flat Panel, for example) you can have the FocusLynx Commander controls and SGP connected at the same time (but you can use just SGP, of course).
