I have encountered a weird bug tonight. I upgraded to beta 366 and tried imaging. The sequence starts, autofocus completes and communication with PhD2 fails. Sequence recovery starts and at this point, Scope Centering hangs (it worked and plate solved successfully before i started the sequence).
If I manually try Solve&Sync, nothing happens. If I launch Center on Target, the Center screen appears and it keeps saying waiting (see screenshot). No plate solving frame is acquired.
I closed PhD2 and relaunched, as well as reset the sequence and restarted and same behavior happened.
I think reverting and having it work was coincidental and due to having everything in a “reset state”. I have fixed the cause of the initial failure… not giving PHD2 enough time to react.
I’ll give Beta 371 a try when I get some clear sky again but I wanted to confirm your suspicion that it was a coincidence that Beta 361 worked. Last night, I was imaging with Beta 361. After some plate solving failures due to clouds, the centering process hung as in the screenshot above. I shut SGP down and restarted it, and centering started working again.
