It seems like there might have been a recent attempt by you to apply an equipment profile to an existing sequence and it went badly somehow. This caused the sequence to fail loading properly and errors behind that were cascading. Did this happen? If it did, did you change the makeup of your filterwheel filters before applying it? I have this fixed, but I am not sure how the sequence was corrupted to begin with.
Hello Ken,
this analysis is totally correct. Is this something I should not have done? I was tired of setting up the eequipment for every new sequence on my office PC setup where I test the beta versions. Therefore I created the equipment profile and found the menu entry to apply it.
Sorry about that and thanks for your help.
Dietmar
