Just on your input there Ken,
I have the stickstation also and have added it in on the equipment profile page. It then shows up ticked in the CP ‘focuser - other’ window that you show here - automatically (as expected). However, I have to uncheck it here again for the temp to actually show up on the focuser docking module. Unsure whether this is a bug in SGP or if it has something to do with RoboFocus wanting to show its temp in the docking module and causing some conflict.
If need be I can try get some screen shots/logs Thurs nigh/Fri morning if you wish.
OK - I’ll now make a bug report re what I described earlier. I think it is directly linked to this topic - I’ll leave it here.
I downloaded and installed version 2.5.0.11 onto the house computer - no astro gear attached. In the equipment profile manager I made a new profile for all simulated equipment, with the exception of environment data input. I used a web link:
(I have deleted the API key from the screen capture.)
I also selected that the focuser (EPM-Focuser-Other) use the ‘Environment device for temperature input’
I restarted SGP and the profile loaded up on the start up sequence (as I had selected it to do).
I connected the Weather station and then the Focuser in that order. This is on screen when I open the windows shown.
I then uncheck the 'Use environment device for temperature input" in the CP-Focus-Other screen and hit enter. The temperature from the environment device now appears. (For the screen capture - I have opened up the CP-Focuser-Other window again…)
This is fixed. I have a brief memory of some very heart felt argument over this stuff… if you were involved don’t worry about rehashing this stuff with me, but, in general, it’s probably a bad idea to use OpenWeatherMap temperatures to control very specific, very localized AF triggers with a very broad, area based temperature. AF triggers are often set to 0.5 or 1.0 C deltas and the temperature can vary by that much just 10 feet away from you on a tiny grass hill.
Again, if you part of the original argument, you don’t need to feel obligated to replay it (I’m just too lazy to search for it) and if it works for you, who am I to say it’s wrong? Just putting this out for out general user base for, most of whom, I suspect, this is not appropriate.
I used online temperature data only to do a test on the home (not OBS computer) so I have no connection with that earlier discussion…in fact I would agree with your position wholeheartedly.
This post is just to confirm that the problem I reported above (Post #23) is indeed fixed (in SGP 2.5.0.12) - thanks!
As of today, the full ASCOM driver with multi-client support is posted on my web site (http://blueastro.se). Along with the driver is a new version of the Windows application that supports connection to the stick automatically as before, to a specified COM-port, and through ASCOM. Using the latter approach is the way to go so that you reap the benefits of both my Windows application’s data storage and GUI, and Sequence Generator Pro - and any other ASCOM application that supports the Observing Conditions interface.
There is also a new firmware that improves the application’s ability to accurately detect the firmware version.
If you consult the manual (;)) you will note that a change of connection method requires an application restart… This is due to some quirks with the .NET serial port class implementation and proper release and I am trying to work around it. So, for now you have to restart if you change from serial to ASCOM… Sorry about that.
I had the same problem as @gingergeek with the stickstation - showed up in SGP (via ASCOM observing conditions hub) but not working via the windows app (with ASCOM driver). Noted that the previous install did not clear from windows - two instances visible in Control Panel/Programs. Cleared all and re-installed the newest…now all working fine with ASCOM driver - can see the info in SGP Environment Data module, Temperature also showing up in my RoboFocus docking module AND can run the windows app (with ASCOM driver) and it shows up there now also.
Hope that helps somebody.
I have new insights
When I use a focus simulator, then the displays the temperature in the SGP focus view
When activate my Ascom focus, the environment themerature not work
I think it works for me - you not only need to set the focuser properties as mentioned above but if you want to see the graph at the same time, you need to use the latest version of Per’s application. This connects via ASCOM hub, rather than a direct link - which locks out other applications from seeing data.
I’ll double check - if I remove the cable from my focuser, it should still read the stick temperature value.
