There is a set of bugs we found on 4.1.0.832 regards cameras settings
on the equipment profile tab you cannot find a ‘Not Set’ entry in camera gain - only 0 -390
on the control panel under camera you can find such a setting so to ignore profile and use the ascom to have to enter it in control panel and save the profile there
So to set the profile so that it uses the ascom gain setting and ignores the profile gain set then you need to manage this under the control panel
In the main equipment profile the gain setting is unable to be selected - the drop down does not work
we had to roll back to an earlier version to get function back
this happened in an earlier version too
This is under an ASI camera (2600MC)
OS: Windows 10
Ver: 4.1.0.832
