BUG with Flats Calibration Wizard
Hi there,
In the rev 3.0.2.94 I can’t achieve the Flats Calibration Wizard.
In the past I already achieved that, but now I enter my information, Filter, BIN, Target Mean, Tolerance, maximum exposure, press start… Without any good result.
The Wizard start at 5 sec , try two time for each filter and declare fails! The wizard don’t try to change the brightness … The wizard do nothing. It’s look like the wizard try fix value and don’t try the 10 attempts like it’s report in the manual.
It’s very helpful this wizard.
Regards
The wizard will not adjust the brightness. You’ll need to determine a decent brightness for each filter prior to starting. From there the wizard will calculate the exposure time for you.
Thank you,
Jared,
Thank you for the answer. But yes the wizard adjust the brightness also! I use an arduino to control my spike-a-flat and per the ADU Value, and the maximum of 5 sec selected, the brightness will varied with the exposure time.
I use your code: https://github.com/jwellman80/ArduinoLightbox
I was able to make it last night after several hour of trouble shooting.
I found the ZWO ASI1600MM-C parameter was change in my profile! So I have highest dynamic range instead of unity gain
I change to unity gain and everything change as expected; exposure time and brightness.
Thank you again for your support and. Fast answer.
Regards
