Can't download lights
Description
The past several nights SGP hangs while downloading light frames. I can do frame a focus and plate solving but when I start a sequence it takes the image and then shows “downloading” but never actually shows the image. I changed cables, removed my USB hub, rebooted several times and changed USB ports but nothing is working. Any ideas?
Aprox time of issue: 10:04pm 4/15/21 and several other nights this week
Link to Logs
Useful Info
OS: Microsoft Windows 8.1 Pro
Ver: 3.1.0.558
.NET: 4.8
I was able to solve this by reading through some of the old posts. Seems like SGP was confusing my guide camera (ASI174mm mini) with my imaging camera (ASI1600MMc Pro). The imaging camera worked fine until I started guiding then it switched the imaging camera with my guide cam and couldn’t download the images. Once I manually reassigned the cameras again it was fixed and connects properly now. It seemed to start when I swapped the guide cam USB cable so I swapped that back too. Working properly again.
