There is a long thread about this but basically you can rotate the image 90 degrees by clicking on one of the rotate arrows at the top. The QHY10 orientation was originally changed because HFR calculation did not work on a rotated image. While the change did fix that problem it broke sub-frames and invalidated old darks/flats.
Well the clouds finally gave way after weeks of horrible weather. I was able to run some tests with the new 2.5.0.23 release and 2.5.1.11beta. It seems the ‘center here’ function is broken again! It worked in 2.5.0.22beta but failed after the landscape view was returned to portrait. If I select a point 180 degrees rotated from the point I want centered everything works as expected.
Other than that I used the new auto focus and it works great.
