I have my sequence set the rotator to 90 degrees with a 0.1 degree accuracy. It does this when the sequence starts, but after a meridian flip the telescope center routine doesn’t check the rotator error. The dialog box said “NA” for rotator position, but the log file says the angle is 90.11, and syncs the rotator to that.
Shouldn’t the auto center routine also check the rotator angle after a pier flip, and ensure it’s less than the specified limit?
I’m running 4.0.0.651 on a Windows 10, latest build PC.
Eric
