Hi
I successfully use SGP in my Observatory
I have purchased a Skywatcher AZ EQ6 mount I have installed EQMOD and Ascom
It all works fine apart from Plate solve ( plate solve 2 ) Settings are as my other setup in SGP.
Last night I tried Framing Wizard . The slew worked fine to the correct location but the centring came up with the error Auto center failed! Aborting auto center (c:1)… (see below log)
Has anyone any thoughts? I guess there is a setting I have missed
Many Thanks
Kieron
d][NONE] Telescope: Slewing to J2000 RA: 12.3805388888889 Dec: 15.7383027777778
[06/18/20 23:19:35.115][DEBUG][CP Update Thread][NONE] Error in control panel UI updater: Object reference not set to an instance of an object.
[06/18/20 23:19:35.115][DEBUG][Slew Monitor][NONE] Waiting for slew to complete…
[06/18/20 23:20:31.671][DEBUG][Telescope Thread][NONE] Center telescope message received…
[06/18/20 23:20:31.675][DEBUG][Telescope Thread][CE;] Solving with Plate Solver PlateSolve2…
[06/18/20 23:20:31.728][DEBUG][Telescope Thread][CE;] Setting filter for auto center…
[06/18/20 23:20:31.730][DEBUG][Telescope Thread][CE;] Could not set the centering override filter! Aborting auto center…
[06/18/20 23:20:31.730][DEBUG][Telescope Thread][CE;] Auto center failed! Aborting auto center (c:1)…
[06/18/20 23:20:31.732][DEBUG][Telescope Thread][CE;] Close centering dialog…
[06/18/20 23:20:31.732][DEBUG][Telescope Thread][NONE] Center telescope message completed…
[06/18/20 23:20:31.732][DEBUG][Telescope Thread][NONE] Telescope thread is IDLE…
[06/18/20 23:20:31.785][DEBUG][Main Thread][NONE] Centering dialog is closed…
