What about this case: a new target/event is added after a sequence has already started? Or is that stupidity beyond fixing?
Also - for folks that have a filter wheel defined, is there a way to warn when no filter (ie. “None”) is selected (before or after a sequence has started)?
I suspected that might be the case. How about doing a check at the point a sequence is saved?
You probably do, for pre sequence start. I guess I was thinking more about post sequence start.
Other approach ideas that could help mitigate:
a) Have default value for all fields set to “NOT SET” or similar value and flag in an obvious way (ie. diff colour etc.)
b) Provide a way for users to define their own “default/template” of values for new Events
c) Provide a “validation” button that forces check for “bad” values
I recognize that these suggestions might not be possible, easy or worthwhile spending time on …
