Yes, likely a copy/paste error. The behavior is that
Mount Park Closes Shutter - When the mount is parked the shutter or roof will be closed.
I’m not even sure what happened here :-/
Park Mount First - This is used to park the mount before the roof/shutter is closed on the observatory. Otherwise the mount park and observatory closing happen simultaneously.
Excellent, thanks Jared. I was on the right track but with this sort of automation it pays to be sure. I have actually given it a run this evening (my time in Oz) and it works well. I am using the Sky Roof controller to control the obs open/close and an external weather sensor to drive the safety function.
