I have a MYT Paramount and have not been guiding with it. I can’t seem to find where the control is to dither if I am not using guiding in the equipment manager. Could someone tell me where I might find this control in SPG with it connected to a paramount MYT?
Not sure what you mean by that last post, but the Direct Mount Guider has nothing to do with PHD2. Instead of picking PHD2 from the dropdown, you pick the Direct Mount Guider and then you can adjust the maximum size of the pulse for dithering between frames.
Thank you, I figured that out while I was setup. It did dither but I got an odd error. I stopped using SPG after that and moved over to TheSkyX.
This is the error. I didn’t think that it was dithering and I didn’t want walking lines. I appreciate the help for next time. Also if I don’t have a rotator will SPG tell me how much I have to rotate the camera if I do mosaics?
