Hi, I just need some clarifaction. Below my measurement I took >
a (RA Centre) 230mm
d (RA Centra offset) 170mm
f (GEm) 360mm
h (RA height) 310mm
A (dome Wall) 1350mm
P (Pier Height) 1250mm
B (P+h) 1560 mm
So, in SGP. The North Offset is the 170mm, the East offset I have it as zero, thr Vertical offset is 310mm, and the GEM is 360mm.
The Radius I have it as 1005mm given that its a 2.1m diameter dome.
If someone can confirm this SGP parameter will be grateful.
Charles
