Pretty much what I described. The same .sgf file that loads fine with all the information when you select “open sequence” from the file menu will just start SGP with no plan loaded if you double click the .sgf file with SGP not running.
It also will load correctly if you drag the .sgf file to the SGP desktop, BTW.
Dunno why it behaves this way, maybe some windows setting (Win 7 64). Not a big deal but not standard windows behavior, which is why I asked.
I’ve noticed this too. Clicking on a .sgf sequence file just opens SGP, not the actual sequence. No biggie, but I’m seeing what CCDMan is describing. It’s been that way since the very beginning of SGP back in the beta days. Again, not a big deal.
