Error capturing during frame and focus!
Hi
I am currently using the latest SGP PRO and a QHY123c with all the latest drivers.
every time i cycle frame and focus i am getting a error message ERROR CAPTURING DURING FRAME AND FOCUS
even when capturing a light frame. I have tried the previous software but no luck
see log attached
well after a laptop restart the problem has gone
but here is the log. I suspect it maybe back
<< Edit by Jared - Removing Log as it was likely truncated anyways…>>
Please zip or attach logs rather than copying and pasting into the message body. Text will get truncated after a certain length. How to report issues or ask for help - Announcements - Main Sequence Software
Not sure what happened but sounds like things are working. Let us know if the problem persists.
Has there been any progress on this issue? I am experiencing it too and it’s maddening.
I’m using a ZWO 1600 mono and cannot even run the flats wizard.
The log reports that the ASCOM driver does not support speed changes and it runs out of memory. I have the driver USB speed set at the lowest speed possible (40). SGP v2.6.0.25
