Error downloading, Pempro (API)
I am trying to use Pempro’s polar align wizard and am running into a problem that appears to be camera related, and possibly SGP related. Basically, when Pempro calls for an exposure that needs to get written to disk for Pempro to analyze, I receive an error message in SGP “Error attempting to capture image” and then “Image failed to save to disk”.
SGP/Pempro can take images just fine for other tasks like PE measurement, it’s just when SGP tries to save the image that there is this problem. At the end of the exposure SGP reads “API call complete”.
If someone could take a look at this log file and give me some advice I’d appreciate it.
Looks like Pempro found the star and tried to take a sub-frame and it was invalid. Check if you have subframes allowed.
I didn’t have subframes enabled in SGP, but Pempro happily takes images with the camera as subframes. For example, I measured PE with pempro for two hours last night and it was constantly taking subframes on a star. It’s just when the image needed to be saved that this error pops up.
I don’t remember needing to enable subframes in SGP before, but I’ll try enabling that and see what happens.
I see this in the log: “ASCOM Camera Error : CheckDotNetExceptions ASCOM.MoravinstCCD.GXCamera StartExposure System.Exception: Invalid subframe horizontal size (NumX). (See Inner Exception for details) (System.Exception: Invalid subframe horizontal size (NumX).)
at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 630
at ASCOM.DriverAccess.MemberFactory.MethodTargetInvocationExceptionHandler(String memberName, Exception e) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 678
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 487
at ASCOM.DriverAccess.Camera.StartExposure(Double Duration, Boolean Light) in c:\ASCOM Build\Export\ASCOM.DriverAccess\Camera.cs:line 595
at q7.h9(pi A_0, rh& A_1)
[02/27/18 21:14:46.529][DEBUG] [Camera Thread] Error while attempting to capture frame…”
The error appears when capturing. I would go to the Pempro forum as ask about this. It may be a PA wizard problem or with the ASCOM driver for your camera. I don’t have your camera to test further. It is strange that the PEC worked fine though, which would lead me to believe there may be a problem with the PA wizard, which I’ve not used yet.
Tonight I tried just using the ASCOM driver from within Pempro and not using SGP. In the Pempro Polar Align Wizard I immediately get the following errors when attempting to capture an image that needs to be saved to disk:
PemproError1PemproError2
So it does appear this is either a Pempro or ASCOM driver issue. I have contacted both Ray Gralak and Moravian so we’ll see what they say.
