I’m going to put a few comments in here, if it doesn’t come out right sorry.
The ASCOM Sync command can be expected to cause the mount to report the current position as the sync position and that a slew to a position near that position will be more accurate. It says nothing about how this is achieved.
Sync can’t be expected to improve pointing globally, and it could easily make things worse.
Sync is usually done in the mount. Early Celestron HCs didn’t have a sync command so I applied an offset in the driver, much as Jared is trying. It works well.
It’s difficult to work for two masters and that is what is happening if SGP is aligning using solve and sync and the mount is pointing using a mount model.
I think that all reports of pointing errors that do not have quantitative information about positions should be ignored. This also applies to offsets in pixels if they don’t specify the pixel scale. It’s almost impossible to do anything but speculate without hard information. Pixel scales can vary hugely so an offset in pixels tells us almost nothing.
As a feature request, could SGP specify the offset errors that it uses to reject or accept positions in arc seconds, not pixels. That would help to make the magnitude of the error that we are talking about clear.
Are people’s expectations unrealistic? A 50 pixel error with a pixel scale of 0.5 arc seconds a pixel is less than half an arc minute. That may be less than the manufacturer’s specification for repeatability for a mid level mount. Would only getting a mount to a position within an arc minute or so be a great hardship?
There isn’t anything in the ASCOM Conform application that tests the sync accuracy, just that the sync command works with no errors reported. I’ve suggested that it be expanded to include something that emulates the solve and sync process and checks the accuracy of the numbers.
(Update, I’ve had a reply and it could be in there fairly soon.)
When you get down to it not using a mount model with SGP works well and for a portable setup saves time. I will put the mount down on the previously set tripod positions, do a quick align, and rely on SGP with it’s solve and sync process to control the mount pointing. The only thing missing is polar align and that’s only an issue if your mount has this in its mount model.
But if I had a high end mount that has a good mount model that will give all sky pointing to significantly better than an arc minute then I’d trust the mount model and not use solve and sync at all.
I wrote most of this a few hours ago and there have been some more comments - I’m really thinking that in some cases people’s expectations are at least close to unrealistic. Getting a mid range mount to significantly less than an arc minute seems to me to be a big ask.
But if you think there is a problem with your mount then you should be talking with your mount manufacturer. Expecting SGP to work round this seems unfair, even if Jared is prepared to be responsive.
Chris
