Event copy doesn't copy Gain settings
The Copy to… and Copy from … options do not copy the current Gain and Offset settings. I need to retype them in and in one case lost a number of subs when the gain was not properly set for a multi-event imaging run. not sure when this happened (it may have been a problem since the incorporation of the copy feature) but I know it didn’t work in the last 5 beta releases.
Pretty sure I fixed this a while back…but we did do some pretty major changes to the events so it is likely that we broke something along the way. I’ll take a look.
Just tested CopyTo and CopyFrom with single and multiple events on the latest beta and the gain is copied through just fine in the Events. Can you detail the steps you’re going through?
