Hi Is it possible to switch on/off the power supply to equipment at sequence start/ end? I can do the electronics bit with a MOSFET if I can get 5v logic to it.
I’m working on a remote observatory which uses 12V batteries as the source of power. The camera in particular uses a lot of current, so I’d like to be able to switch it, especially off at the end of a sequence.
Is this possible in SGP? I’ll also check the availbility of an ASCOM switch driver in case SGP can connect to it.
I checked the SGP help file, but only found mentions of safety switches.
thanks
Paul
right - just seen switches in the ONLINE help file. I think this is what I want. I looked in my V4 helpfile and ‘switches’ does not appear. Perhaps it would be good to keep the help file up to date by using a link to the web help from SGP. Just a thought.
Paul
