Windows 7
SGP 2.3.13
Eqmod Ascom
This is my second time running into this issue. I was asleep when it happened, so the only information I have is the data in the log file. When I did look at SGP however, there was a dialog stating “Failed to meridian flip, telescope not near meridian…”.
I lost the chance to capture a few more frames… My last successfull meridian flip dates back to 2.3.11 or 2.3.12.
I will try a test target and see if I can gather more data on the meridian flip. I had recovery enabled, but it seems that the error dialog essentially blocked the rest of SGP from running.
[7/4/2014 3:02:27 AM] [DEBUG] [Sequence Thread] ------------- Starting capture frame for event[0] -------------
[7/4/2014 3:02:27 AM] [DEBUG] [Sequence Thread] Created base name for frame capture: Pelican Nebulae_300sec_1x1__frame26
[7/4/2014 3:02:27 AM] [DEBUG] [Sequence Thread] Created directory for frame capture: C:\Users\astro\Pictures\Pelican Nebulae\Light
[7/4/2014 3:02:27 AM] [DEBUG] [Sequence Thread] Sending commands…
[7/4/2014 3:02:27 AM] [DEBUG] [Sequence Thread] SetFlatBox: Frame Type is non-flat
[7/4/2014 3:02:27 AM] [DEBUG] [Sequence Thread] Checking if Meridian Flip is needed
[7/4/2014 3:02:27 AM] [DEBUG] [Sequence Thread] Telescope is on the West side of the mount
[7/4/2014 3:02:43 AM] [DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model…
[7/4/2014 3:02:43 AM] [DEBUG] [MF Update Thread] Performing serialize…
[7/4/2014 3:05:47 AM] [DEBUG] [Sequence Thread] Meridian Flip needed, Hour Angle >= Degrees Past To Flip: -0.00701265027237241 >= 0
[7/4/2014 3:05:47 AM] [DEBUG] [Sequence Thread] Running blocking meridian flip…
