I found a odd behavior of Falcon Rotator with Sequence Generator pro. I will try to describe the situation (example)
- I have object with rotation angle od 337 deg.
- When i start the session, Rotator go to position given by SGP - 337 deg
- Check in SGP reveal that there is a 0,5 deg error and try to move rotator not by 0,5 deg but to absolute position of 337 deg
- Rotator didn’t move because it is at 337 deg
- SGP after fail tries to repeat step 3.
Did you encounter that problem? Is there a way to move rotator not to absolute posiot but “by desired angle”?
I will be gratefull for any help because now I must manually move rotator by 0,5deg.
Thank you and best wishes
Link to Logs (Log is very long. I did a lot of testing, but the issue is there)
Useful Info
OS: Microsoft Windows 7 Enterprise
Ver: 3.2.0.660
.NET: 4.8
