% File Name: not loading new default
I’ve changed my preferred default directory and preferred naming convention for files in the Sequence Generator screen.
The new default directory loads properly, but not the naming convention. I can past into the sequence and all is well, but it won’t load automatically with anew sequence.
Hi eclise
Make sure you ‘Save Sequence as Profile’ and this will overwrite the Equipment Profile with the settings in the current sequence (in which you have changed the file name pattern) and apply this to all new sequences created with that profile.
Please note that if you amend any setting within a sequence this change only applies to that sequence and will not apply to the underlying Equipment profile unless you opt to ‘Save Sequence as Profile’ or alter the profile manually.
HTH
Barry
Thanks Barry. I tried that and got an error and my entire profile vanished. I think there was probably a glitch in the profile. I have been messing with it a lot lately as I’ve been exploring the program. In any event, I was able to load a recently created sequence, change the naming structure and save that sequence as my new default profile and everything is working as expected. Yeah!
