While I’ve read through many of the threads related to Meridian flips and Platesolving, I made several attempts at Platesolving after the Meridian flip with failure.
This was the first time I did a meridian flip and I was pleased that SGPro handled it with ease. However, I can’t figure out why plate solving didn’t work.
Starting the Sequence is an ease and the platesolver always puts my imaged square centre for multi-night imaging - Excellent!
Camera: ZWO ASI 1600MM Cooled
Mount: Celestron CGEM
Guide camera: ZWO ASI 120MM
PHD2 (latest version)
SGPro (latest version)
firmware updated for CGEM and handcontroller
Latest drivers for mount and cameras
for whatever reason the PS2 solve failed after the meridian flip. that is probably not necessarily a smoking gun depending on your mount, telescope, etc. however, the backup blind solve failed as well:
is your imaging computer connected to the internet? have you ever been able to do a blind solve outside of a sequence?
I also have the CGEM mount and if I attempt a solve within about 15 seconds of a large slew the mount is still moving enough that the stars are short streaks. This sometimes makes solving difficult even with a blind failover. Also, the CGEM is notorious for having about 3,000 pixel error after a large slew and therefore 100 search regions is nowhere close to enough. However, since blind failover should be immune to this, it could come back to a smudged image that would be fixed by increasing your mount settle time.
I purposely used the plate solving coordinates in the intital sequence so when I’m in the field and don’t have access to the internet, plate solving will still function. However, I will test this at home with the scope and see if that solves the problem. Thanks for your suggestions!
Thanks Generator - good to know about the CGEM. I will increase the settling time and also increase the search regions from the current 100 to a higher number until the max is reached. I do notice that at high magnification my stars are oval and all seem to be in one direction. I’ve got a HOTECH 3-laser collimator so I think I’ve dialed in my collimation as good as it will get. I use a Bahtinov mask to focus as best as possible, so those issues are covered off. At normal zoom out, the stars look fine and deconvolution with PI seems to help. Perhaps it’s too aggressive guiding? FWHM is typically 4-6 in the city and of course lower in a dark zone. RMS is tyically around 1.2-1.6 arc-sec so I think this is pretty good.
Anyhow - thanks for your insight and suggestions regarding the CGEM and star ‘smudging’
i will be honest with you - i have no idea what this sentence means.
if you want plate solving to work in the field, you need to use a solver that does not rely on the internet. the built-in PS2 solver does not require an internet connection to function. however, the astrometry.net backup solver does require an internet connection to function. the only way to get the astrometry.net solver to work in the field without internet is to download and configure a local copy of the solver; there is a package called ANSVR that you’ll need to install.
as for your oval stars, the way to rule out collimation issues is to point the tube straight up (right now is a good time with the summer milky way high above - lots of star) and take short exposures (1-2 sec) which should eliminate any guiding or other mount issues. if you have oval stars in this situation, then your collimation needs work. if they look fine, then you may have differential flexure issues between the guide camera and main camera (unless you are using an OAG, which for the most part eliminates this problem.)
What meant was that I have the coordinates already loaded for frame and focus for the DSO I want to image and then use PlateSolver 2 to find and center the subject, prior to imaging.
I’ll try the vertical experiment you suggested and see if there’s any difference.
Note that the star shape I was mentioning came from 300 sec NB frames.
