Hi SGP
I have been using the program for two years now, but over the last two nights while running the second Focus routine during a run (The first was run at the start of the sequence) the camera looses USB comms and the temp goes to zero. Here is a cut and paste form the log.
Any idea why the focus routine would turn off the cooler?
[04/02/21 23:12:02.245][DEBUG] [Camera Thread] Turning temp comp off… More lines below.
I have swapped USB cable and USB port and it happened again tonight.
I use the Sesto Sensa Focuser and driver from Prima Luce. Atik 11 meg is my camera. I m using the ASCOM 6.4 I think version to get SGP comms to the camera.
Thanks Tom.
[04/02/21 23:12:02.213][DEBUG] [Sequence Thread] Checking if Meridian Flip is needed
[04/02/21 23:12:02.214][DEBUG] [Sequence Thread] Telescope is on the West side of the mount
[04/02/21 23:12:02.214][DEBUG] [Sequence Thread] Meridian Flip not needed, Hour Angle < Degrees Past To Flip: -34,3891186868593 < 2,5
[04/02/21 23:12:02.214][DEBUG] [Sequence Thread] EventMarker 3 - t:M89 M90 (0); e:0; f:2; o:
[04/02/21 23:12:02.215][DEBUG] [Sequence Thread] Waiting for AF to complete…
[04/02/21 23:12:02.221][DEBUG] [Camera Thread] SGM_FOCUSER_AUTO_FOCUS message received…
[04/02/21 23:12:02.221][DEBUG] [Camera Thread] Checking for auto focus…
[04/02/21 23:12:02.221][DEBUG] [Camera Thread] Auto focus required (frame count trigger)…
[04/02/21 23:12:02.232][DEBUG] [Camera Thread] Auto focus: setting filter Lum
[04/02/21 23:12:02.232][DEBUG] [Camera Thread] Setting filter position 1…
[04/02/21 23:12:02.232][DEBUG] [Camera Thread] Filter position 1 is already set. Skipping…
[04/02/21 23:12:02.234][DEBUG] [Camera Thread] Auto focus running…
