I’ve set my 183mc pro camera’s gain and offset via the ascom driver so do I still need to set it in the sequence? I see a field for it in the Event Settings, but I’m unsure if I NEED to set it there as well. Also, why is the offset greyed out and why is the offset not captured in the FITs header? Thanks in advance.
Gain and offset in SGP is working perfectly with some upgrades, newest Ascom, SGP and camera drivers should make it work.
After this you can control gain and offset directly in SGP and the FITS header will also have the values saved.
