GUI vs. automation bug
Good Morning Jared,
So with all of my various drivers coming together, last night I ran a fully automated run with autofocus, etc. Unfortunately about an hour after I went to bed it failed due to PHD losing the guide star which in turn was due to SGP failing to finish a focus properly (a regular event that I need to investigate, but given that it seems to always happen on the last move, I’m not sure it is in my driver). At any rate, the reason for this post is that while I’d told SGP to park and disconnect the equipment, when I got up this morning the dialog asking if I wanted to turn off the camera cooler was still up. That shouldn’t block an automated command to shut everything down, but it is.
Beo
Hi Beo
I run two automated rigs, one at a remote location and one at my home obs. I have never seen this dialogue before.
Have you ticked the option in the Camera tab to ‘warm up’ as part of End of Sequence options? This will automate the warm up following which SGP will disconnect from the ccd.
Barry
Hi Barry,
I don’t use the warm-up routine, but the reality is that shouldn’t be necessary. Regardless of the function, if the system is running fully automated, a blocking dialog should never pop up. That’s certainly against the ASCOM standard and should also be the case for client design.
Beo
Ya, that’s odd. What version SGP?
Not sure what this has to do with ASCOM…? But in our case we use a timed dialog. Essentially we will tell you something is about to happen. If you’re in front of the scope it gives you an opportunity to take action. If not we go on with what we’re doing. The Camera warm up should be one of those.
Hi Jared,
I’m running the latest version, but as mentioned to Barry, I’m not running a warm up delay but just shutting down equipment like I would manually. Presumably that provides a different prompt. Regarding the ASCOM comment, there’s always the possibility that the driver (QHY) is asking the question, although I don’t think that’s the case.
Beo.
So FYI, here’s the dialog:
SGP%20Camera%20Cooler
Problem is repeatable.
Beo
