Hi, I think I may have this right, calibrate PHD2 and guide for a minute. Stop guiding. Click on ‘run sequence’ and hopefully the scope goes to, and centres on, the target with the help of plate solving. Then the guiding kicks in.
My question is how does PHD2 find a guide star? I presume it’s through some sort of ‘auto select star’. Is that command sent by SGpro as I can’t find a tick box for that to happen.
I guess I just need a bit of enlightenment.
Kind regards,
P.
i think by default PHD2 will auto-select a guide star if it is not already on one when sgp asks phd to start guiding (meaning that there is a green box around a star.)
in fact if there is no calibration, i think PHD2 will calibrate when asked to guide, but it’s probably better to get that sorted out before SGP is talking to PHD2.
rob
Yes, I think you’re right Rob. I tried a sequence last night without calibration and the sequence ran ok until it came to guiding, then a message came up, ‘RA calibration failed, star did not move enough’. Makes more sense now, thanks.
P.
Important to take a darks library in PHD2 so you don’t try to guide on a hot pixel.
I too have had a couple of issues with PHD2 and SGP and I would like to confirm the proper way to invoke PHD2 (I’m a relatively new user)?
I’ve been using two different methods
Start PHD2 outside of SGP, calibrate, begin guiding, stop guiding and then hit run sequence (as outlined in the original post). On occasion I have found that after plate solving and centering on the target SGP will hang and not be able to restart the guider forcing me to quit both programs and then restart.
The second method I have used is to not start PHD2 separately but rather just hit start sequence and have SGP invoke PHD2. PHD2 then runs through its calibration sequence and begins guiding.
Are ether of these two methods correct? Is one better than the other or is there another method I should be using?
Bob
I like to manually plate solve for centering (right click on the target to do this), start PHD2 guiding and then start the sequence. Not so good for fully automated operation, but it assures me that everything is set up correctly before starting exposures.
When you do these steps, the slew to target and plate solve options have to be off on the target. Then when you start the exposure SGP will warn that the target may not be centered which of course you can ignore.
Heads up to Ken and Jared, this warning message is unnecessary. Could SGP determine that you just did a manual center an not issue the warning?
In theory, I believe, you should be able to do second method where SGP will:
- Start PHD
- Connect guide equipment
- Initiate Calibration routing
- Pick guide star
- Start guiding
I leave PHD running all the time so not sure that #0 is true - perhaps others can confirm.
Occasionally, I have an issue (including last night!) where #1 fails and SGP starts recovery process.
I’ve never had an issue with SGP progressing with #2-#4.
If I’m planning to kick off of an unattended sequence, I will manually connect equipment in PHD2 first, before starting sequence count-down.
DaveNL
