I plan on using my phone as a mobile hotspot at my site in case I need to use internet to frame a photo. I was wondering how much data a simple search would use to make sure I stay below my data limits! Has anyone tested this before?
Thanks.
Thanks.
If you mean use Astrometry.Net to solve an image then the image will need to be transferred. We don’t know how big your images are.
Simplest is to try it and see what it costs.
I can’t imagine it’s very much. You’re not downloading high resolution
video. If you have your targets in mind before you leave you can download
the images at home and they are stored in the cache so even without
internet the framing and mosaic wizard can pull up any image you have
searched for (unless you cleared the cache).
I have set up local plate solving so that won’t be an issue.
I meant if I want to frame a new photo it’s going to download a reference
photo, I was wondering how big those images were. I image at 1.8"/pixel
with a ~3 degree FOV.
Ideally I’d not try it out and get hit with a huge bill if I don’t have to.
I’m not entirely sure to be completely honest. But they get saved with the sequence file so you could create a new sequence, use the Framing and Mosaic Wizard and then save the sequence. The size of the sequence should give you a decent ballpark.
But as Joel mentioned they’re not large, probably a few megs.
