How to rearrange/specify order of process execution
Hi all,
I tried looking around the forums and the manual, but either I couldn’t figure out the right words to use, or just can’t find the right article for what I’m hoping to do. Basically, I’m hoping to be able to change the order of setting up steps/routines when an event starts or being resume.
For example, on first run of the sequence, I would like the execution to happen in the following order:
  1. From home/parked position, set Empty (no filter) filter in EFW (focuser set for that filter)
  2. Slew scope and plate solve to center
  3. Set Ha filter (as per first event to run) in EFW (focuser set for that filter)
  4. Run AF routine
  5. Start PHD2 guiding (using OAG, therefore focus must be set first)
  6. Sequence starts capturing
These do not happen at the moment, which causes the processes to wait on each other, and stuck in an infinite loop. If this is not the way to do it, please advise how should I have all those equipment working together?
Not sure if it’s necessary, but the equipment I’m doing this on are:
  • TSA-120 with FL 900mm
  • ZWO OAG with QHY5L-M-II
  • SW AZ-EQ6 running EQMOD
  • Pegasus auto focus system
  • ZWO ASI1600MM Pro
  • ZWO 8 position filter wheel (L/R/G/B/Ha/OIII/SII/Empty)
  • Laptop for control
Thanks in advance,
Brendan
SGP doesn’t allow you to specify the order in which things happen. However there are some options which help:
  • “Auto focus before sequence start” this is in the Auto Focus Options dialog.
  • For your targets select “Slew To” and “Center on” in the target settings.
  • Do you really want Auto focus to run with your Ha filter in place? Better option is to setup offsets and use the “Auto Adjust Focus per filter” option so your auto focus runs don’t take 15 minutes.
  • On the plate solve tab you can set the filter to use for solving.
Thanks Jared. I guess the biggest problem is the guiding. On initial run, PHD will try to find a guide star and calibrate. But at the same time, SGPro is running autofocus, which throws the OAG out causing PHD not able to find a guide star to calibrate/settle. SGPro then comes around and waits for PHD to settle, and the loop continues. That’s why I was hoping if there is a way to rearrange or at least do something so PHD does not do anything until all the other steps are finished, that way it has a semi/focused star to do its thing?
Be assured, if you have set everything up correctly, these issues you are having will go away completely. This whole initial sequence process runs perfectly, night after night.
Tell PHD2 to not quide when doing a focus run.
Set Lum for your filter for the focus run.
Set Lum for your filter for plate solving.
As Jared suggests, use offsets for your Ha filter, don’t do focus runs on Ha during imaging. Just find out what your Ha filter offset is.
On the Auto Guide tab set the “Pause guiding during auto focus” option which will stop this from happening.
Even better than what I was expecting! Thanks guys :slight_smile: :+1:
