How to setup scope control with Stellarium via SGP?
Using the option for external telescope control in SGP I started the TCP server and setup a new scope in Stellarium to connect to the remote server on the network. I am able to connect with no problem, however I am not able to control the scope or view it’s position in the sky. I am wondering if anyone has set this up successfully and what I may be doing wrong? I see Sky Safari should be compatible with it, but I don’t want to purchase it just to see in case it doesn’t work. Is there any sort of logging that can be turned on to show the TCP server console output?
