Info on Importing targets
I have a problem importing targets from AstroPlanner and Deep Sky Planner. Both are at latest releases, as is my SGP.
I have seen one post that says everything works fine. But it does not for me. I have searched here on this Forum, and see reference to the problem, and even one comment that it was discussed and srettled some time ago. But I cannot find that discussion. If somebody could point me to it, that would be great. .
At any rate, I save the export file from AstroPlanner or Deep Sky Planner, and then go to SGP to import. The import function in SGP cannot find the file.
AstroPlanner has named the file “xxx.txt” and SGP is looking for an XML file. I have not found out how DSP has named it, but if I type in “xxx.txt” instead of the DSP default “XXX” SGp can find it. So, I can work around and get the targets loaded from either program, but I feel like I am missing something I should be doing.
Can anybody tell me what is happening? And perhaps how to fix it in my approach.
Alex
There is some guidance for correctly exporting things here:
http://www.mainsequencesoftware.com/Content/SGPHelp/TargetImports.html
If that doesn’t get things working, attach the files here and I can see if something is wrong.
Thank you, Jared…I had read through all that documentation in the manual on my computer. Curiously, my edition of the support manual did not match the support manual you referred me to. I thought I had the most recent edition of the program on my computer. (3.0.2.94…which is now apparently out of date!). I updated to 3.0.3.140 and still have a support manual which does not match what you referred me to.
IS it possible that my support manual was not updated when I updated the software? Does one update the manual separately?
The document you referred me to indicates that the anomaly has been fixed in AstroPlanner 2.3. Unfortunately, I cannot find reference to a download to AstroPlanner 2.3 on their website!!! SO I am still in 2.2.
And the support manual you referred me to makes no mention of Deep Sky Planner.
But I appreciate the suggestion.
I have done more exploring. Both these programs (AstroPlanner 2.2 and Deep Sky Planner) have inconsistencies in how they add the appropriate file extension. Then, when SGP import function goes out to look for them in the file chooser, it only shows those files with the expected extension. It looks like the “export” file does not exist, when in fact it is there, with the wrong file extension and just does not show.
The work around is to type in the whole file name (even the wrong extension!) and SGP will find it and work with it. (Actually, just the first few letters of the file name will do.)
Thank you for your attention to this.
Alex
Ya, that’s pretty likely. Updating the manual in SGP is a manual step. I need to see if I can add that into our build process.
I don’t think we have the Deep Sky Planner process documented…but I’ll double check that it’s not in the manual and just not built. If you can upload a file from Deep Sky Planner I’ll go through the code and document the process.
Thank you,
Jared, I’ll get back to you in a bit. May be two weeks (after Nightfall Star party). Not a big deal. But I want to do get back to you in private, outside the Forum.
Alex
Oh, and by the way, the program does support Deep Sky Planner. It is just a case of having to type in the whole file name (or the first few letters) because SGP cannot find the file when the extension is not added by the program. I have checked with the DSP people and they agree that (typing in the name) needs to be done in some cases. Specifically, in generating the Export file (while in DSP) one needs to add the “.txt” extension when using the first screen, but after clicking the “Folder Chooser” icon, their subroutine will add the extension automatically.
It is just that the help manual does not so describe the DSP import.
At any rate, the problem is not the file itself, it is just that SGP does not display it in the chooser unless one has somehow successfully added the extension. Once found, it works fine.
Alex
Just for information Astroplanner 2.3 is actually a beta version and you can get it from here. AstroPlanner Beta Testing
