I have an Ioptron CEM40 and got an Ioptron focuser for it. SGP recognizes the driver, but there is no control of the focuser. Is there a way, and can I do autofocus?
Peter Bresler
Peter Bresler
Are you getting an error or anything? Can you post a log?
I will send a log when I can. I did get the focuser to work with SGP. I connected a USB cable to the hand controller. I zeroed the focuser racked out all the way and then could use the buttons or “goto” to set the position. The problem I just discovered is that when I restarted after powering on, the focuser position had been lost. It looks like I would have to set the zero every time I turn it on?
Peter
