Issue - flat wizard failed
General info
Adding flats to the sequence raised an error message and created an empty target added to the sequence
Link to Logs
Useful Info
OS: Microsoft Windows 10 Pro
Ver: 3.1.0.431
.NET: 4.8
Thx for the report. Will be fixed in 3.1.0.432. This issue was with the “Pause” options. Until then, just avoid using the pause options and add it manually to the new target.
Thanks Ken, I confirm, if the pause options are not used, then it works as expected.
