I looked through the logs and everything seems OK. I can’t remember what the error tolerance for DEC is (based on search regions), but the actual position differs from the reported position by about a minute. I think PS2 should be able to work with that, but I’m unsure. I would suggest:
Trying ASTAP
Saving the plate frame that PS2 fails on and posting it (right click -> Save As FITS)
Click “Help -> Open Log Folder”. Find “PlateSolve2.ini” and delete it. Go to PlateSolve2 settings again (recreates the ini file you deleted). Reset your catalog directories. Try again
