I see the meridian flip process begin but for some reason the slew ends up on the same side (West) and the meridian flip fails. This is befuddling since i have tried sgp meridian delay of 10 and 20 minutes. The meridian flip process begins but fails.
Here is a VERY brief snippet of SGP and the asom driver for The Sky X at the specific time the meridian flip fails. It seems there is something more fundamental which I am missing - unrelated to Paramount MX settings in The Sky X.
----------------Sequence Generator Pro log file snippet ---------------------
[04/08/21 22:17:46.403][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Sending Telescope command to execute meridian flip
[04/08/21 22:17:46.417][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Pier side is West
[04/08/21 22:17:46.417][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: attempting pier flip using slew
[04/08/21 22:17:46.440][INFO][Telescope Thread][SQ;MF;] Telescope: Using “OFFSET” sync option, updating slew cooridnates with offsets:
[04/08/21 22:17:46.440][INFO][Telescope Thread][SQ;MF;] RA: 0.695613378889688 hours
[04/08/21 22:17:46.440][INFO][Telescope Thread][SQ;MF;] DEC: 72.889414560264 degrees
[04/08/21 22:17:46.440][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slewing to J2000 RA: 10.4342006833453 (10h26m03.12s) Dec: 72.889414560264 (72°53’21.89")
[04/08/21 22:17:46.440][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slew received J2000 coordinates, mount requires JNOW, converting…
[04/08/21 22:17:46.441][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slewing to JNOW RA: 10.4630622887931 Dec: 72.7855193296347
[04/08/21 22:17:53.519][DEBUG][Telescope Thread][SQ;MF;] Scope reports it is done with synchronous slew, verifying…
[04/08/21 22:17:53.521][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slewing has completed
[04/08/21 22:17:53.521][DEBUG][Telescope Thread][SQ;MF;] Telescope: Settling for 20 seconds
[04/08/21 22:18:13.522][DEBUG][Telescope Thread][SQ;MF;] Telescope: Settling has completed
[04/08/21 22:18:14.022][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Failed to flip because starting pier side and ending pier side are the same!
[04/08/21 22:18:16.024][DEBUG][Telescope Thread][SQ;MF;] Telescope thread is IDLE…
[04/08/21 22:18:16.042][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Telescope command to meridian flip has completed
[04/08/21 22:18:16.055][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Telescope failed to perform meridian flip
[04/08/21 22:18:20.530][DEBUG][Main Thread][SQ;] Adding sequence level notification: Failed to complete automatic meridian flip, aborting sequence!
[04/08/21 22:18:20.565][DEBUG][Sequence Thread][SQ;] Sending Notification: Error - Failed to complete automatic meridian flip, aborting sequence!
[04/08/21 22:18:20.643][DEBUG][Pier Flip Thread][SQ;] Meridian Flip: Procedure complete
[04/08/21 22:18:26.643][DEBUG][Sequence Thread][SQ;] Blocking Pier Flip: Failed to meridian flip, aborting sequence (True)
[04/08/21 22:18:26.644][DEBUG][Sequence Thread][SQ;] Aborting sequence: Failed to meridian flip
[04/08/21 22:18:26.644][DEBUG][Sequence Thread][SQ;] Set sequence abort
[04/08/21 22:18:26.649][DEBUG][Main Thread][SQ;] Adding sequence level notification: Failed to meridian flip, aborting sequence.
[04/08/21 22:18:26.686][DEBUG][Sequence Thread][SQ;] Sending Notification: Error - Failed to meridian flip, aborting sequence.
-------------------------- ASCOM driver for TSX snippet ------------------------------
22:17:45.970 Tracking Get - 1 = True
22:17:46.187 CanSlewAsync Get - True
22:17:46.189 m_SkyTele.GetRaDec Ra 10.2285355379941, Dec 71.0076917098785
22:17:46.189 RightAscension Get - 10.2285355379941
22:17:46.189 Declination Get - 71.0076917098785
22:17:46.191 Altitude get - 57.6441017005067
22:17:46.192 Azimuth Get - 358.472228265324
22:17:46.215 SiderealTime Get - 10.3960694694438
22:17:46.217 SideOfPier Get - pierWest, sop 1
22:17:46.412 SideOfPier Get - pierWest
22:17:46.417 SideOfPier Get - pierWest
22:17:46.417 CanSlewAsync Get - True
22:17:46.419 m_SkyTele.GetRaDec Ra 10.228536105935, Dec 71.0076906587426
22:17:46.419 RightAscension Get - 10.228536105935
22:17:46.419 Declination Get - 71.0076906587426
22:17:46.421 Altitude get - 57.6440810061473
22:17:46.422 Azimuth Get - 358.47159431566
22:17:46.437 SiderealTime Get - 10.3961307464294
22:17:46.437 SideOfPier Get - pierWest
22:17:46.439 Connected Get - True
22:17:46.440 CanSlew Get - True
22:17:46.442 SlewToCoordinates set - 10.4630622887931, 72.7855193296347
22:17:46.442 SlewToTarget set - 10.4630622887931, 72.7855193296347
22:17:51.289 CanSlewAsync Get - True
22:17:53.521 m_SkyTele.GetRaDec Ra 10.4607695568667, Dec 72.7842008667967
22:17:53.521 RightAscension Get - 10.4607695568667
22:17:53.521 Slewing IsSlewComplete 1, slewing False, slewState idle
22:17:53.521 Declination Get - 72.7842008667967
22:17:53.523 Altitude get - 55.8905802887112
22:17:53.524 Azimuth Get - 0.496107226606057
22:17:53.547 SiderealTime Get - 10.3981117026342
22:17:53.547 SideOfPier Get - pierWest
22:17:55.731 Connected Get - True
22:17:55.977 Connected Get - True
22:17:55.980 SideOfPier Get - pierWest
22:17:55.982 AtPark IsParked = False
22:17:56.002 Tracking Get - 1 = True
22:17:56.340 CanSlewAsync Get - True
22:17:56.343 m_SkyTele.GetRaDec Ra 10.4607702942176, Dec 72.7841892424416
22:17:56.343 RightAscension Get - 10.4607702942176
22:17:56.343 Declination Get - 72.7841892424416
22:17:56.345 Altitude get - 55.8906715922038
22:17:56.346 Azimuth Get - 0.489848140589118
22:17:56.372 SiderealTime Get - 10.3988943959979
22:17:56.373 SideOfPier Get - pierWest, sop 1
22:18:01.420 CanSlewAsync Get - True
22:18:01.422 m_SkyTele.GetRaDec Ra 10.4607702526059, Dec 72.7841984522472
22:18:01.422 RightAscension Get - 10.4607702526059
22:18:01.422 Declination Get - 72.7841984522472
22:18:01.424 Altitude get - 55.8908019647369
22:18:01.425 Azimuth Get - 0.478685478947426
22:18:01.445 SiderealTime Get - 10.4003135495719
22:18:01.446 SideOfPier Get - pierWest
22:18:05.734 Connected Get - True
22:18:06.007 Connected Get - True
22:18:06.010 SideOfPier Get - pierWest
22:18:06.012 AtPark IsParked = False
22:18:06.034 Tracking Get - 1 = True
22:18:06.477 CanSlewAsync Get - True
22:18:06.478 m_SkyTele.GetRaDec Ra 10.460772273426, Dec 72.7841777282691
22:18:06.479 RightAscension Get - 10.460772273426
22:18:06.479 Declination Get - 72.7841777282691
22:18:06.481 Altitude get - 55.8909589823685
22:18:06.481 Azimuth Get - 0.467529142395477
22:18:06.528 SiderealTime Get - 10.4017251835462
22:18:06.535 SideOfPier Get - pierWest, sop 1
22:18:11.578 CanSlewAsync Get - True
22:18:11.580 m_SkyTele.GetRaDec Ra 10.4607703348753, Dec 72.7841867089277
22:18:11.580 RightAscension Get - 10.4607703348753
22:18:11.580 Declination Get - 72.7841867089277
22:18:11.582 Altitude get - 55.8910845223523
22:18:11.582 Azimuth Get - 0.456249766542015
22:18:11.611 SiderealTime Get - 10.403139327815
22:18:11.611 SideOfPier Get - pierWest
22:18:14.022 SideOfPier Get - pierWest
22:18:15.736 Connected Get - True
22:18:16.101 Connected Get - True
22:18:16.107 SideOfPier Get - pierWest
22:18:16.108 SideOfPier Get - pierWest
22:18:16.109 AtPark IsParked = False
22:18:16.129 Tracking Get - 1 = True
22:18:16.591 CanSlewAsync Get - True
22:18:16.593 m_SkyTele.GetRaDec Ra 10.460770163363, Dec 72.784196166004
22:18:16.593 RightAscension Get - 10.460770163363
22:18:16.593 Declination Get - 72.784196166004
22:18:16.595 Altitude get - 55.8912033776185
22:18:16.596 Azimuth Get - 0.445224599695649
22:18:16.621 SiderealTime Get - 10.4045414811508
22:18:16.622 SideOfPier Get - pierWest, sop 1
22:18:21.668 CanSlewAsync Get - True
22:18:21.670 m_SkyTele.GetRaDec Ra 10.46077218196, Dec 72.7841754380318
22:18:21.670 RightAscension Get - 10.46077218196
22:18:21.670 Declination Get - 72.7841754380318
22:18:21.677 Altitude get - 55.8913507107016
22:18:21.677 Azimuth Get - 0.43407214721995
22:18:21.699 SiderealTime Get - 10.4059520057198
22:18:21.699 SideOfPier Get - pierWest
22:18:25.739 Connected Get - True
22:18:26.183 Connected Get - True
22:18:26.184 SideOfPier Get - pierWest
22:18:26.185 SideOfPier Get - pierWest
22:18:26.186 AtPark IsParked = False
22:18:26.220 Tracking Get - 1 = True
22:18:26.696 CanSlewAsync Get - True
22:18:26.699 m_SkyTele.GetRaDec Ra 10.4607700838807, Dec 72.7841847461456
22:18:26.699 RightAscension Get - 10.4607700838807
22:18:26.702 Declination Get - 72.7841847461456
22:18:26.704 Altitude get - 55.891465111768
22:18:26.704 Azimuth Get - 0.422901879151027
22:18:26.717 SiderealTime Get - 10.407352220306
22:18:26.718 SideOfPier Get - pierWest, sop 1
22:18:27.038 Connected Get - True
22:18:27.039 AtPark IsParked = False
22:18:27.045 Park start
22:18:27.129 Connected Get - True
22:18:27.132 SideOfPier Get - pierWest
22:18:27.133 SideOfPier Get - pierWest
22:18:31.697 CanSlewAsync Get - True
22:18:31.699 m_SkyTele.GetRaDec Ra 10.7129319205533, Dec 76.7026290119135
22:18:31.699 RightAscension Get - 10.7129319205533
22:18:31.700 Declination Get - 76.7026290119135
22:18:31.707 Altitude get - 51.9224257993362
22:18:31.707 Azimuth Get - 1.70019164213659
22:18:31.723 SiderealTime Get - 10.4087454644923
22:18:31.724 SideOfPier Get - pierWest
22:18:35.742 Connected Get - True
22:18:36.286 Connected Get - True
22:18:36.292 SideOfPier Get - pierWest
22:18:36.294 AtPark IsParked = False
22:18:36.308 Tracking Get - 1 = True
22:18:36.743 CanSlewAsync Get - True
22:18:36.745 m_SkyTele.GetRaDec Ra 11.4422904907584, Dec 87.3836610318576
22:18:36.745 RightAscension Get - 11.4422904907584
22:18:36.746 Declination Get - 87.3836610318576
22:18:36.748 Altitude get - 41.1957609081759
22:18:36.748 Azimuth Get - 0.927870921054932
22:18:36.774 SiderealTime Get - 10.410154027939
22:18:36.775 SideOfPier Get - pierWest, sop 1
22:18:41.753 CanSlewAsync Get - True
22:18:41.755 m_SkyTele.GetRaDec Ra 1.55389916093684, Dec 89.4962314208232
22:18:41.755 RightAscension Get - 1.55389916093684
22:18:41.756 Declination Get - 89.4962314208232
22:18:41.758 Altitude get - 38.3343151879597
22:18:41.763 Azimuth Get - 359.529269445381
22:18:41.806 SiderealTime Get - 10.4115556321583
22:18:41.806 SideOfPier Get - pierWest
22:18:45.749 Connected Get - True
22:18:46.355 Connected Get - True
22:18:46.358 SideOfPier Get - pierWest
22:18:46.359 AtPark IsParked = False
22:18:46.373 Tracking Get - 1 = True
22:18:46.815 CanSlewAsync Get - True
22:18:46.822 m_SkyTele.GetRaDec Ra 2.99394371806279, Dec 89.5135614899108
22:18:46.822 RightAscension Get - 2.99394371806279
22:18:46.823 Declination Get - 89.5135614899108
22:18:46.824 Altitude get - 38.499946504248
22:18:46.825 Azimuth Get - 359.420836309835
22:18:46.841 SiderealTime Get - 10.4129558467722
22:18:46.842 SideOfPier Get - pierWest, sop 1
22:18:51.856 CanSlewAsync Get - True
22:18:51.857 m_SkyTele.GetRaDec Ra 3.94859989686526, Dec 89.5332185326153
22:18:51.857 RightAscension Get - 3.94859989686526
22:18:51.857 Declination Get - 89.5332185326153
22:18:51.862 Altitude get - 38.6196842945226
22:18:51.862 Azimuth Get - 359.406994292321
22:18:51.872 SiderealTime Get - 10.4143599612026
22:18:51.873 SideOfPier Get - pierWest
22:18:55.774 Connected Get - True
22:18:56.401 Connected Get - True
22:18:56.405 SideOfPier Get - pierWest
22:18:56.436 AtPark IsParked = False
22:18:56.480 Tracking Get - 1 = True
22:18:56.907 CanSlewAsync Get - True
22:18:56.969 m_SkyTele.GetRaDec Ra 4.34354103045509, Dec 89.5459208041631
22:18:56.969 RightAscension Get - 4.34354103045509
22:18:56.971 Declination Get - 89.5459208041631
22:18:57.006 Altitude get - 38.6681938736802
22:18:57.036 Azimuth Get - 359.418619989847
22:18:57.179 SiderealTime Get - 10.4158231225519
22:18:57.217 SideOfPier Get - pierWest, sop 1
22:18:58.233 Park done
22:18:58.270 AtPark IsParked = True
22:18:58.305 Slewing IsSlewComplete 1, slewing False, slewState idle
22:19:01.965 CanSlewAsync Get - True
22:19:01.976 m_SkyTele.GetRaDec Ra 4.35127988554729, Dec 89.5461472029341
22:19:01.976 RightAscension Get - 4.35127988554729
22:19:01.977 Declination Get - 89.5461472029341
22:19:01.979 Altitude get - 38.668690809133
22:19:01.980 Azimuth Get - 359.418795001069
22:19:01.996 SiderealTime Get - 10.4171768190961
22:19:01.997 SideOfPier Get - pierWest
22:19:05.776 Connected Get - True
22:19:06.433 Connected Get - True
22:19:06.436 SideOfPier Get - pierWest
22:19:06.437 AtPark IsParked = True
22:19:06.983 CanSlewAsync Get - True
22:19:06.985 m_SkyTele.GetRaDec Ra 4.35268180488787, Dec 89.5461472288821
22:19:06.985 RightAscension Get - 4.35268180488787
22:19:06.986 Declination Get - 89.5461472288821
22:19:06.988 Altitude get - 38.6686919443518
22:19:06.988 Azimuth Get - 359.418795337352
22:19:07.038 SiderealTime Get - 10.4185856627149
22:19:07.038 SideOfPier Get - pierWest
22:19:12.034 CanSlewAsync Get - True
22:19:12.038 m_SkyTele.GetRaDec Ra 4.35408305702199, Dec 89.5461469219664
22:19:12.038 RightAscension Get - 4.35408305702199
22:19:12.038 Declination Get - 89.5461469219664
22:19:12.040 Altitude get - 38.6686907704683
22:19:12.041 Azimuth Get - 359.418794979623
22:19:12.069 SiderealTime Get - 10.4199791870735
22:19:12.070 SideOfPier Get - pierWest, sop 1
22:19:15.780 Connected Get - True
22:19:16.499 Connected Get - True
22:19:16.532 SideOfPier Get - pierWest
22:19:16.565 AtPark IsParked = True
================== END SNIPPETS =============
