Mosaic offset
Hi , New user of SGP , and the mosaic wizard. Did a 4 panel Mosaic of NGC6888 , 2 left panels , 2 right. not too bothered about the camera angle , but noticed the resulting mosaic had the left 2 panels higher than the right 2 panels. Ie I thought a 2x2 block would result in a stitched rectangular mosaic ??.
Anyone seen these symptoms ?
Regards Trevor
Can you post a screenshot of the resulting stitch as well as what you setup with the Framing and Mosaic Wizard?
Hi , I have recreated the mosaic , but it is very similar to the original , also the resultant image
Regards Trevor
If the camera angle is wrong in the mosaic wizard compared to the actual angle it will create a mosaic like this
Trying to get my head round it , the mosaic wizard presents me with a view rotated to the same angle as the camera, I naively thought what you see you get ie placed 4 panels centrally and click away :frowning:
Nb , my camera angle has been entered into equipment profile ( 349 degrees )
Thanks for your response
Trevor
I believe you are correct. Once you plate solve an image you can check the rotation angle and make sure it is still 349 and if not, make them match again and try it.
You are correct that the framing and mosaic wizard will rotate their example image to align with your position angle.
Hi I did find a difference in the recorded camera angle ( input during initial setup )
Taken from a recent image : 359
Actual angle reported from the above image : 269
So need to test again and report back.
Regards
