Hi
SGP and PHD2 both connected to my scope through Ascom.
Both using Ethernet (through wifi).
Works like a charm, but…
If I start navigating the captured images from within SGP, I start getting ASCOM errors “telescope connection failed”. It does recover after a while, but autoguiding failed during that period and got unusable frames until the error was recovered.
Is it a known issue?
Rodolphe
No, haven’t heard anything like that. Can you easily reproduce that? Can you post a log?
You have exceeded the capacity of your serial port. This is not an ascom or SGP issue. Bruce
Hi
Thanks for the hint.
I’m.not using serial ports except if you consider USB is a serial port, which is used by SGP to download images from the camera and by PHD2 for the same.
Guiding instructions to the mount all go through the Ethernet interface.
Where can I find the logs?
Rodolphe
Rodolphe.
What is the specifications your computer? When SGP cycles frames it’s sort of intensive sometimes, it could be it’s slowing the computer down too much for the serial/usb to function properly.
Hi
Surface Book, I7-6600U proc (2.6GHz), 16 GB of RAM, 512 GB SSD.
I dare to think this should be sufficient for the task!
Rodolphe.
Yeah plenty… So during the day can you reproduce this? Just have your SGP connected to the mount, have PHD2 looping black images… Then try drag-drop images into SGP to force it to load the image while the mount is tracking.
It honestly sounds PC - USB - related as much as it seems.
Hi
I tend to agree although I cannot relate it to the image navigation.
Anyway will give it a try to reproduce as you suggested, will report back.
Thinking back on my setup, I use an amplified USB extender cable from the laptop to the mount where it is connected to a powered USB hub serving the guiding and imaging cameras; this to avoid multiple cables running from the PC and to have enough leeway between the pc and the mount. Maybe this should be revisited.
Kind regards
Rodolphe
Just a thought. Have you checked advanced power settings? USB bandwidth may well be the issue. Sometimes, although the processor is high power, these slim PCs dispense with graphics and I/O sub processors for economy.
Hi
Tried that but running Win10 – not possible to change the USB power settings in the advance power settings, at least not through the standard ways (ie control panel).
Rodolphe.
I think @buzz was referring to the USB power settings. Go to Control Panel; Select Device Manager; drop down Universal Serial Bus Controller; open each device and go to the Power Management tab; uncheck Allow the computer to turn off this device to save power
Ah OK makes sense. Will also give it a shot.
Rodolphe.
They also dispense with clocking the processor at full speed once you start processor intensive tasks. Your 2.3GHz could actually be as low as 600MHz to keep the processors cool. Welcome to the world of poorly cooled tablets where you don’t get what you paid for unless it is only reading email.
