Haven’t had a chance to setup and try out the new SGP3 update. Does anyone have any information on what the new guiding options mean for the Direct Mount Guider?
In the control panel it now gives options for 2s to 30s. In the equipment profiles it still shows Small Dither to Extreme Dither.
Just wondering which one takes priority or how the two interact, and what movement the 2s-30s of dither will give.
Not sure what you mean by priority. This option is for unguided imaging where you still want a dither between frames.
The options are actually from .1 sec to 30 sec…
The 1 second option corresponds to the previous setting (last version) of “Extreme Dither” The options were changed to allow better control of the dither, especially for those using wide field optics such as camera lenses.
Note that the options for a guided dither have not changed, they still use the older terminology. For these new unguided dither options, typically you would want maybe 1-5 seconds at 200 mm, less for longer focal lengths and more for shorter.
Thanks for the info. It is for unguided dithering that i’m after the information for.
I was wondering now how the different settings correlated to each other. The control options are in seconds, and the profile settings still using the old description. For example if you put 5s in the control dialogue but had ‘Small Dither’ in the equipment profile, how the two settings would correlate. Would the control dialogue options take precedence on how the mount dithers, or would the equipment profile setting have priority if it was different.
