I am wading in waters way over my head and need advise/help. I am hoping you can help or steer me in the right direction. I have just installed the NexDome Rotation Kit for my observatory. I have installed the Windows ASCOM driver for the NexDome (NexDome/windows/installer at master · grozzie2/NexDome · GitHub).
After installing the driver “NexDome” is now a choice in the drop down menu in Equipment/Observatory.
After selecting “NexDome” I am able to control the Dome, which is good. However, an error message always pops up:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040402): Timed out waiting for received data
at ASCOM.Utilities.Serial.ReceiveCounted(Int32 Count) in C:\ASCOM Build\Export\ASCOM.Utilities\ASCOM.Utilities\Serial.vb:line 1033
at ASCOM.NexDome.Dome.CommandString(String Command, Boolean Raw)
at ASCOM.NexDome.Dome.DomeCommand(String Command)
at ASCOM.NexDome.SetupForm.TimerEventProcessor(Object myObject, EventArgs myEventArgs)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2115.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Sequence Generator
Assembly Version: 2.6.0.23
Win32 Version: 2.6.0.23
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Sequence%20Generator.exe
System.Configuration
Win32 Version: 4.7.2046.0 built by: NET47REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System
Win32 Version: 4.7.2110.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.7.2116.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ServiceStack
Assembly Version: 3.9.48.0
Win32 Version: 3.9.48.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.DLL
ServiceStack.Interfaces
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Interfaces.DLL
System.Xml
Win32 Version: 4.7.2102.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Serialization
Win32 Version: 4.7.2112.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Newtonsoft.Json
Assembly Version: 4.5.0.0
Win32 Version: 4.5.8.15203
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Newtonsoft.Json.DLL
System.ComponentModel.DataAnnotations
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
RestSharp
Assembly Version: 104.1.0.0
Win32 Version: 104.1.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/RestSharp.DLL
ServiceStack.ServiceInterface
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.ServiceInterface.DLL
ServiceStack.Common
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Common.DLL
ServiceStack.Text
Assembly Version: 3.9.45.0
Win32 Version: 3.9.45.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/ServiceStack.Text.DLL
System.Web
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
ASCOM.DeviceInterfaces
Assembly Version: 6.0.0.0
Win32 Version: 6.3.0.2821
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DeviceInterfaces/6.0.0.0__565de7938946fba7/ASCOM.DeviceInterfaces.dll
GraphLib
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/GraphLib.DLL
MediaSlider
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/MediaSlider.DLL
System.ServiceModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
System.Data.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
ASCOM.Utilities
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Utilities/6.0.0.0__565de7938946fba7/ASCOM.Utilities.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.2046.0 built by: NET47REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
ASCOM.DriverAccess
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DriverAccess/6.0.0.0__565de7938946fba7/ASCOM.DriverAccess.dll
ASCOM.Astrometry
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Astrometry/6.0.0.0__565de7938946fba7/ASCOM.Astrometry.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.WindowsAPICodePack.Shell
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Microsoft.WindowsAPICodePack.Shell.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Sequence%20Generator/Microsoft.WindowsAPICodePack.DLL
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
ASCOM.Interfaces
Win32 Version: 1.0.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Interfaces/1.0.0.0__565de7938946fba7/ASCOM.Interfaces.dll
ASCOM.Exceptions
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Exceptions/6.0.0.0__565de7938946fba7/ASCOM.Exceptions.dll
CustomMarshalers
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
ASCOM.NexDome.Dome
Assembly Version: 6.2.0.0
Win32 Version: 6.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/Dome/ASCOM.NexDome.Dome.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<system.windows.forms jitDebugging=“true” />
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box
Can you help with this or do I need to try and get ahold of whoever wrote the ASCOM driver?
Appreciate any help.
Tony
