PHD graph with oag?
First night with an OAG.
Everything seemed good and the guiding was not perfect but not bad. The outside swings were less than 2.
But the graph displayed in SGP was like amplified, worse I have ever seen. Even though the graph in PHD2 seemed 'normal.
What did I miss?
You can click on the PHD graph in SGP to change the zoom level. Maybe you were more zoomed in than normal?
I knew that should have mention that. First thing I checked. It was bad at all three scales.
It is as if the scale in sgp was 3x more sensitive than the one in PHD. For every .1 in PHD the graph in SGP was out to .3 or more?
Also setteling, it was out at 1.5 or so I went and checked PHD and it was at like .2 of course the image would not start.
I was just hoping there was some setting I had overlooked.
I assume you were using guide scope before switching to OAG. If the guide scope focal length is less than main scope, did you change the focal length setting to match your main scope in PHD2? This will properly calculate and scale PHD2 graph better. Using OAG means the guide and main scopes both have same focal length and focal length of main scope is longer than your previous guide scope, PHD2 graph can look bouncier if it was scaled for guide scope. If you change focal length to match your main scope in PHD2, PHD2 graph should look better. To change focal length setting in PHD2, it’s under “Guiding” tab of Advance setting. Also, if you change guide camera with different pixel size, you will need to update PHD2 to change pixel size (under “Camera” tab of Advance setting).
Since focal length of guiding is now longer with OAG, you will probably need to increase Minimum Move to reduce number of corrections sent to the mount.
Peter
Thanks Peter, yes I made the changes in PHD2 made a separate profile for it.
Using Starlight Express Lodestar X2 with pixel scale of 5.3, and focal length of 2,000 for the RC10.
Maybe the guiding was just that bad! Seems odd though.
The star shape display in phd2 was horrid even though it appeared to be in focus with a nice sharp peak.
Well SGP only displays the pixel scale and Phd2 can switch between pixels
and arcseconds. Maybe you’re on the arcseconds view in phd?
Jared Wellman
– Co-Founder and Developer
– www.mainsequencesoftware.com
That is possible, although I went back and checked the profile I was using and it was set for pixels.
But I will consider this next time I get out. Thanks.
Just as another data point, I have always used refractors before recently switching to a 10" RC myself. With the refractors the stars in PHD looked generally round and “nice”. Not so much with the RC. The stars I see in PHD are now slightly distorted, like a little cross. I assume this is because the OAG is picking off light from the edge of a much more spherical surface than a refractor has, but guiding has been great for me so far.
That is interesting to know, thanks. I noted that oof stars look kind of like crescent moons instead of doughnuts.
Once in focus they seem weird like this is a lot of coma or something.
Perhaps your right picking off the edge of a true parabola might lead to this.
Guiding for me has been hit and miss so far but still getting things configured. But, per usual, it will be late next week before I can do any further work on it due to clouds and rain in the forecast.
That makes a huge difference. If it was displayed in arcsecs, then you should see less bouncy graph.
Peter
What do you mean by pixel scale? To calculate image scale and assuming you didn’t bin Lodestar (8.3 uM pixel):
(206.3 * 8.3) / 2000 = 0.856 arcsecs/pixel
If you binned Lodestar, multiply by 2 to get 1.712 arcsecs/pixel.
Where did you get pixel scale of 5.3?
Peter
I miss spoke. Pixel ‘average’ size is 5.3 with the lodestar.
I think you mis-spoke again. Lodestar pixel size is actually 8.2uM x 8.4uM which is an average of 8.3uM.
Peter
Yea 8.3, it was tired and I was late. Anyhow it was set correctly.
Not important at this time. Wont really know until I get another actual session.
Thanks for the input.
