Okay I see two problems in your settings, Frank. Depth 1-10 is only going to check the 10 brightest objects in the frame. You’re also only specifying 50 objects but it will only use 10 due to the depth setting.
Here’s what I have:
M001 solved on objects 1-10 using index 4108
log-odds ratio 660.552 (7.48095e+286), 93 match, 0 conflict, 195 distractors, 99 index.
RA,Dec = (83.755,21.9691), pixel scale 2.04562 arcsec/pix.
Hit/miss: Hit/miss: ++++++++++++±+++++++++++++++++++++±++++±±+++±±±+±+++±++±+±++++±+±-±±±-±+++±–±-±
Field 1: solved with index index-4108.fits.
Field 1 solved: writing to file M001/M001_120sec_1x1_L_frame6.solved to indicate this.
Field: M001_120sec_1x1_L_frame6.fit
Field center: (RA,Dec) = (83.76, 21.97) deg.
Field center: (RA H:M:S, Dec D:M:S) = (05:35:01.288, +21:58:08.012).
Field size: 1.90773 x 1.44084 degrees
Field rotation angle: up is 73.9738 degrees E of N
M042 - solved using objects 11-20 index 4110 - so you would fail to solve this because of depth.
Also the downsampling process takes slightly over a minute
Field 1 did not solve (index index-4111.fits, field objects 11-20).
log-odds ratio 132.018 (2.16181e+57), 20 match, 0 conflict, 129 distractors, 28 index.
RA,Dec = (83.7594,-5.45927), pixel scale 2.04544 arcsec/pix.
Hit/miss: Hit/miss: ±------±±-±------++±—±—++±--------------------+±--------±+±---------±--------±------
Field 1: solved with index index-4110.fits.
Field 1 solved: writing to file M042/M042_120sec_1x1_HA_frame3.solved to indicate this.
Field: M042_120sec_1x1_HA_frame3.fit
Field center: (RA,Dec) = (83.76, -5.46) deg.
Field center: (RA H:M:S, Dec D:M:S) = (05:35:02.397, -05:27:34.915).
Field size: 1.9066 x 1.44214 degrees
Field rotation angle: up is 68.5175 degrees E of N
M048 - solved using objects 11-20 index 4111 - so you would fail to solve this because of depth.
log-odds ratio 235.315 (1.57106e+102), 26 match, 0 conflict, 58 distractors, 30 index.
RA,Dec = (123.707,-5.84929), pixel scale 2.04474 arcsec/pix.
Hit/miss: Hit/miss: +++±±-+++±–±++±±±±–+±—±-----+±–±------±–±----±----------------+(best)----------------
Field 1 solved: writing to file M048/M048_120sec_1x1_B_frame3.solved to indicate this.
Field: M048_120sec_1x1_B_frame3.fit
Field center: (RA,Dec) = (123.7, -5.849) deg.
Field center: (RA H:M:S, Dec D:M:S) = (08:14:49.602, -05:50:57.144).
Field size: 1.90744 x 1.4404 degrees
Field rotation angle: up is -112.067 degrees E of N
M064 - solved with objects 1-10 index 4209 - should solve for you
Field 1 did not solve (index index-4210.fits, field objects 1-10).
log-odds ratio 300.536 (3.32005e+130), 42 match, 1 conflict, 88 distractors, 46 index.
RA,Dec = (194.039,21.7951), pixel scale 4.08739 arcsec/pix.
Hit/miss: Hit/miss: +++++++++++++++++±+++++±±±-+±–++±±-+±—±–±+±---------±-----------±----------c-------
Field 1: solved with index index-4209.fits.
Field 1 solved: writing to file M064/M064_120sec_2x2_B_frame3.solved to indicate this.
Field: M064_120sec_2x2_B_frame3.fit
Field center: (RA,Dec) = (194, 21.8) deg.
Field center: (RA H:M:S, Dec D:M:S) = (12:56:09.146, +21:47:44.206).
Field size: 1.90734 x 1.44058 degrees
Field rotation angle: up is -111.652 degrees E of N
M094 - solved using objects 1-10 - you can and did solve this with index 4111
Field 1 did not solve (index index-4112.fits, field objects 1-10).
log-odds ratio 56.732 (4.34885e+24), 5 match, 0 conflict, 0 distractors, 8 index.
RA,Dec = (193.106,40.7781), pixel scale 2.04416 arcsec/pix.
Hit/miss: Hit/miss: +++++(best)-----------------------------------------------------------------------------------------------
Field 1: solved with index index-4111.fits.
Field 1 solved: writing to file M094/M094_300sec_1x1_G_frame3.solved to indicate this.
Field: M094_300sec_1x1_G_frame3.fit
Field center: (RA,Dec) = (193.1, 40.78) deg.
Field center: (RA H:M:S, Dec D:M:S) = (12:52:25.236, +40:46:42.158).
Field size: 1.90674 x 1.44095 degrees
Field rotation angle: up is -111.293 degrees E of N
M109 - solved using objects 1-10 index 4209
log-odds ratio 376.275 (2.59525e+163), 45 match, 0 conflict, 147 distractors, 50 index.
RA,Dec = (179.287,53.4128), pixel scale 2.0457 arcsec/pix.
Hit/miss: Hit/miss: ++++++++++++±-+++±-+++++++++±+++±-+±±-+++±—±–±–±-±-----------------------------------
Field 1 solved: writing to file M109/M109_120sec_1x1_B_frame3.solved to indicate this.
Field: M109_120sec_1x1_B_frame3.fit
Field center: (RA,Dec) = (179.3, 53.41) deg.
Field center: (RA H:M:S, Dec D:M:S) = (11:57:08.889, +53:24:46.747).
Field size: 1.90731 x 1.44048 degrees
So what we have is this:
- You can’t solve anything using anything but the 10 most brightest objects so remove your depth setting entirely
- I have solved all plates using objects 1-150 so set your objects to 150. I have found if it takes more than 150 then it won’t solve anyway
- I checked the code in fitsbin.c and you will get a “Couldn’t find table xxxx in file yyy” any time the an FITS file is missing a table. That verifies what Andy said about corrupt indexes. We know for sure that 4201-13 is corrupt (but you don’t need it anyway - see #7). To find out which others are corrupt download this http://md5deep.sourceforge.net/ and do an MD5SUM on all your index files. I’ll paste below what they should be. Anything with a different value should be replaced with a fresh copy. I’ll put my MD5SUMs at the end of this.
- I see you are using the G or B filters for some of the images. That should be okay but a Lum filter is better and a blue is better than green for most CCDs. You might want to set Lum in SGPro in the plate solving control panel.
- I solved all of these plates in less than 70 seconds with the majority of them taking 20-30 secs to down sample, and 10 or so to solve except for M042 which took about 2m to downsample…
- The number of index files isn’t important if SGPro is sending the arcsecs per pixel. It will use only the ones that match the image resolution.
- Your camera is 1.9 x 1.4 degrees. You need down to about 10% of your widest field for index files. For you that is .14 degrees or 8.4 arc minutes. You need the index files from 4219-4204-. You will not use 4203, 4202*, 4201*, and 4200* with your camera. When solving it starts as 4219 and works to 4200-* because the indexes are named after the scale so 4219 is larger scale than 4218. It tries to solve less resolution to more. You do not need the 41xx files I have. Those are for wide field solves. You should have index-4204-* thru index.4219. Anyone wanting to know what index files they will use, take your smallest axis in degrees after a solve times 0.6 then check the table here: Astrometry.net code README — Astrometry.net master documentation.
Sums of Wide Field
f963cdd3bae5aa985d2245464ef444d6 index-4107.fits
e6a3a643fa06cbbdf1dee478e4d84a32 index-4108.fits
9a65a52ce04e3e75af950e5866f81b1b index-4109.fits
d9aeb509b107d3bf8f79346329f1c0e3 index-4110.fits
cd7c149671d92a430bbe64c046ffcac3 index-4111.fits
76568e3703f492121a1affca7368f3c2 index-4112.fits
d36a7d5f06b0443f7951751733b1b088 index-4113.fits
0afbed8177b0e101dfc8925c5c077005 index-4114.fits
0db912aba86fa97159add4a65833ec10 index-4115.fits
b70cb06f819144de4c659524a735f4f3 index-4116.fits
ccf0ef3e8faac6feb0f5fb74d88a3152 index-4117.fits
a99b85c89f16e6d1ab6dbc19d9ac1d1a index-4118.fits
25c404b35a08558a1404d3f6145abf1c index-4119.fits
Sums of Narrow field to 4 arc mins
d693d40a270f9013cab23edd50293afb index-4202-09.fits
db742a45ce2bc02cca1a65cbbdd83a48 index-4202-10.fits
66980cf1b678c2b2a6df82d636c82823 index-4202-11.fits
92a15d3cc0c1662d97388f69951b215b index-4202-12.fits
ac98621888fb0a923344c76b34b2f025 index-4202-13.fits
68c74f207c052d4f6098ba2cd2c9de15 index-4202-20.fits
42c95dae99914f2a2ee17f46791da0d4 index-4202-21.fits
c22ad52358469df01774551f7e52a0fc index-4202-22.fits
407ba0618105eac82b09915e2762ff12 index-4202-23.fits
5ee4e8a7cbaad923e3d3b066cd992f36 index-4202-24.fits
cce43310e71cab55df914675801c008d index-4202-25.fits
0c87c9dd931341e4c7a45b52b313a1fb index-4202-26.fits
f51bd5a1eb5286b6c23f568e610c65c8 index-4202-27.fits
0567e9a8d19008556441c8e653bd6aef index-4202-28.fits
9dbcdb3e64688a5a6f439d1c8e321c5b index-4202-29.fits
be89b8215779416a4bb554e84c464cc9 index-4202-30.fits
19f92d783215d40b23e9542c5502775f index-4202-31.fits
1c1b9e26ea76690a7cafd7d0c73c1bc8 index-4202-32.fits
37d22e1d79391343b8deb7f8279938da index-4202-33.fits
a82668feff833182ad3ee0d183320c5e index-4202-34.fits
1b4cc661c394fae1cb2f87f42121fca5 index-4202-35.fits
77aeb35d00bde46abdc5a89e1f751a01 index-4202-36.fits
c765d040c5472b68ae9f2dbabc051a00 index-4202-37.fits
d90259e4444bfdffe92e77d267f1ad9a index-4202-38.fits
0044a8f79ce2aa6182b99db82514401d index-4202-39.fits
0a52133226b38eac139cfc63069a91ee index-4202-40.fits
5d5c442275e3f08e71756aea8a28f608 index-4202-41.fits
16117481f45f6a4636a5d43ff144e05c index-4202-42.fits
fc9b34016e5b27fdba27b1191dff5a3c index-4202-43.fits
ebde7203fa6ed67d3feba41053ebdad4 index-4202-44.fits
18fbfc7142f9a3900110d211b4a92eaa index-4202-45.fits
9f882e372fb39743ed404f35b81b84eb index-4202-46.fits
80bc34e94f0d3cb2a8c7b97d35683450 index-4202-47.fits
ee059e006a719ccceb7696a2be29257d index-4203-00.fits
175e610b05d518672c9192b07ee8e258 index-4203-01.fits
396d9cca24ce1ee8f39b46585a78e92e index-4203-02.fits
734ba7fd44bdc2696aab5333067522d3 index-4203-03.fits
e6e7dba53edd5455338f6aa84f8aadc5 index-4203-04.fits
8fd39a6c0d4094cdd432a95358f50195 index-4203-05.fits
f01f8dfafba623428e6fd1fa20f1b60a index-4203-06.fits
e334101d4169ce07125adb7c0521d3f9 index-4203-07.fits
aa0b52e94f774ecb67366c2b3e15e5e2 index-4203-08.fits
1e191868dbf0cbb1963f2a3c056a1fd1 index-4203-09.fits
149d645aea611dc9d6e696fb339bc430 index-4203-10.fits
0d51797943af6158746b07786c8917d8 index-4203-11.fits
43e106c7d84d59fa5b4d35944fdb7a9a index-4203-12.fits
391505c99f8ee3ab5045f152d7ae4eb2 index-4203-13.fits
1730ff70b3e8e1914e8da13caaf22495 index-4203-14.fits
867fb56676d09a5a31140aa0efc85895 index-4203-15.fits
4758c64318d0583fdb03717d59df15be index-4203-16.fits
977dd7a62ad93d6281ca53cc500ae429 index-4203-17.fits
82ed3702bf8dc4fbdfe629f67cc541c4 index-4203-18.fits
f234a828e81762673209d12ccc453fb7 index-4203-19.fits
608c17e90e1413ce93ad84e7cb954e3d index-4203-20.fits
74a72f655e3799ddf104715cc1fb75ee index-4203-21.fits
5e4c327d08609cf45798ea46a7b11e56 index-4203-22.fits
604a89d5f1c68bcf633cdbb1aa2caf7c index-4203-23.fits
8a3be15c995d938f6a11e3f0e113ef74 index-4203-24.fits
6c82762dcdd489868b4b87961eae47c7 index-4203-25.fits
5dca9b3901cb1e96d7be4a227e877c7e index-4203-26.fits
fca9e3ca8cab308f164b8a8685bd3baa index-4203-27.fits
6956a4c32c58520bf594e02877a44620 index-4203-28.fits
709965eab3906499152f2149c3d41398 index-4203-29.fits
ff44f6f683d3cbb3c040ba89e297c558 index-4203-30.fits
c619bac89bc35d2b8ba9ac25c4259aa7 index-4203-31.fits
335101fc751f5937c94f805f891f8685 index-4203-32.fits
c505e59b27853aaf9b7cf33dedf1e7f0 index-4203-33.fits
14684a843d50a795ab97dc0b4c063d01 index-4203-34.fits
d38711209387ae1566c88f2a6eebd2fe index-4203-35.fits
e164bd26e8b5440c8aba4c3c4178809f index-4203-36.fits
067c3b0b3153863e1430f5767feb39d9 index-4203-37.fits
1108c767d23efb7bb53337fbf7b3d155 index-4203-38.fits
09c29489e9fbc1dd5ec6e9f62b7a2b64 index-4203-39.fits
607ba03cddacbc673ac5404132e5678a index-4203-40.fits
4b2999cd398697dab8511d9e830ae0bf index-4203-41.fits
381a4a9c7f051ac00388657a4242bdb8 index-4203-42.fits
9269dacfd3609e48c721b00b14f24a5c index-4203-43.fits
22d54cd920d9aa88366dcf63e6ed14fb index-4203-44.fits
8e6cf4a868e087c4878232f4548ae65c index-4203-45.fits
440bae39994d6b0b9a782c1203ee7f90 index-4203-46.fits
c5adeffd16aee06ba68288cae9af2c3f index-4203-47.fits
43e3049c13c98563ca5abfd8589e8a6c index-4204-00.fits
738a8b91ac99d74d3ab8c1cf7a479152 index-4204-01.fits
1122eb86dd21f503d4a0ab2d9d3fd681 index-4204-02.fits
c31a0210d48f99275da5a014a7d3a1cd index-4204-03.fits
837182ea240a1733f9ebece4cea30fe8 index-4204-04.fits
6b415298a9418d59ff952e2438ef2fbd index-4204-05.fits
2d5a0352eac0cd3bdb436dbbc14120cc index-4204-06.fits
f1f9ccf4f03fd59573dedc28b95e3124 index-4204-07.fits
3cdff77454b95df95051ff0de8a8736b index-4204-08.fits
ddbd58e7bde99dfb9459735f48700adc index-4204-09.fits
3a12c567d58a2a26bb5c2d288bb0be59 index-4204-10.fits
52663a7b92efad0ece6bfd0222b645fb index-4204-11.fits
931660e7ab8eeb193ff95ff5c8a832b3 index-4204-12.fits
f05ba6f64aad32992656fbafd2bc2b15 index-4204-13.fits
39eb81b54dc307f96c2b0c72d987903b index-4204-14.fits
b643670e452327b6568429389d15c2b1 index-4204-15.fits
01624f2ea855be3b60ba63116b95d926 index-4204-16.fits
d2c146bee92438f1c585908b6e9a613b index-4204-17.fits
59be7a21ef214443f7eb23d503a202ad index-4204-18.fits
9c34ed4e2a4efed350edc201dc9fb1fd index-4204-19.fits
c12a8eb9e04a371a03b771fbe151575d index-4204-20.fits
df1b2f9767e1b23303dd60f1b8e39e4b index-4204-21.fits
d040798ce5417cdb78e675f1d0b30857 index-4204-22.fits
0f25e3872caba1a01810d80ccb4b7798 index-4204-23.fits
993012cc037c3e8cfa2412f1bd0f9926 index-4204-24.fits
02a6ae14cbf68e6fb7d2c8bb1b0c9ec2 index-4204-25.fits
c7dec9bda5132a79236c2a7be8ed395d index-4204-26.fits
55442517d36d6fef2709e209111e69b5 index-4204-27.fits
3910ff38dc528b7cd1e0803cbc14c80c index-4204-28.fits
c6a6ed56b5602d888477267f3d44ce77 index-4204-29.fits
5f48f81e511858afdd7b303a6144e385 index-4204-30.fits
e3e3deed3bfba8a6b0f53011cd0ac8b9 index-4204-31.fits
ffc5493828665f6e6b4da5b8b987c5d2 index-4204-32.fits
f206556da41752a7922ef1e4a87377c6 index-4204-33.fits
50bc7534ccb9e2f7ca21790434c4a290 index-4204-34.fits
fa4506a71d7ae2f26165a29e4daccae0 index-4204-35.fits
77a39ddea411c08b6cfa780c8e8d83ee index-4204-36.fits
861bbc3951473fb4d5c0dd2aaac22b3b index-4204-37.fits
d7808bfa079e20cfe917c0804485455e index-4204-38.fits
06566a8c639a2638f6793e94871e4acb index-4204-39.fits
3d5b33845c8a5e97ebb6efe67dbebd46 index-4204-40.fits
104385a4dc2ad0a9ed0f3f848856a667 index-4204-41.fits
5c49500ffce437ea6b84c793f2559181 index-4204-42.fits
57221ed3e7e2610dfab10d0971ea6955 index-4204-43.fits
b7dbe51a7171ef016c9276ed2556eca6 index-4204-44.fits
a8e866b3c89a8ae6e0f8c76f9f369655 index-4204-45.fits
bac788ab3755ca7d75a349a205cb1528 index-4204-46.fits
950dbecea2a98b3a2f0b83bad9f70365 index-4204-47.fits
920b54f14b5ee68780e4f5e1f1132def index-4205-00.fits
0674bc153e2d58f9cbd3fbbd8ee35032 index-4205-01.fits
f1f9bfa549abd40d731a3d8382488045 index-4205-02.fits
d5a7b993523062886d17af938648d73d index-4205-03.fits
18b947879cd49e80d970cb76ab07af77 index-4205-04.fits
2e66e17b97083adb0e41b54819c5cfa2 index-4205-05.fits
abd741644bcde142c845ce0b2d1b3791 index-4205-06.fits
c55714dd1f27a74adfa2c9937dc00138 index-4205-07.fits
07ad195476c2115d73ba7df902c93e61 index-4205-08.fits
dbd8513c6c328b7275302e50144f62b8 index-4205-09.fits
baca0a586ff36d8345eaff3a6c8c071b index-4205-10.fits
894ccdbd9d8b2ac69693bd7d9862e8aa index-4205-11.fits
d346096ad3218f8694a2676931f98c10 index-4206-00.fits
277d7da550aba6b717df1311cd90c963 index-4206-01.fits
f5ce1aa735b06ec984462671ef6bc66e index-4206-02.fits
d0605eddd4544a445627e6e4ae2a8a1f index-4206-03.fits
a49e82c7ea88d0c3a45b36da52619d3a index-4206-04.fits
d987c5c2def80789862a56bdd8a2a00c index-4206-05.fits
f6c5d6da3844984d33d591e72833625a index-4206-06.fits
cbf7ba26681274d9c3490541fac1610a index-4206-07.fits
3772dccbc198ad851564a17ca14944b3 index-4206-08.fits
65514ddc576316efaf554fff505cae20 index-4206-09.fits
c9b87d5a64265e4db5a5852351d2c159 index-4206-10.fits
cb461080181a2aa6e9114266a842d26e index-4206-11.fits
13b65b37d5ceca7278a98ad4779cc5f7 index-4207-00.fits
d9a2a92e3106ff09b1b6efab18e47488 index-4207-01.fits
ab339cbd34534a4075752eb046be2a85 index-4207-02.fits
a25cb3f103be06b7908e195996a1e624 index-4207-03.fits
030b91123b6f338bffb214dc20fbb723 index-4207-04.fits
0aa51a0b2bbe5b6a9e1f539060cbbcbf index-4207-05.fits
234948c09eab7ef42c5558b475031980 index-4207-06.fits
37267d6d302444b548239bcc68c18b16 index-4207-07.fits
341c662971c9f1368619baf491c5d59c index-4207-08.fits
1f2d7c9847a05ce3d741eb35cee19988 index-4207-09.fits
3d07b8e27d8a6fd5801aa6bef2b17dc2 index-4207-10.fits
fb88bf437d6a39082534da13048ff0bd index-4207-11.fits
815a5a4d1d234376453ba3372f473859 index-4208.fits
764db3e2d62c24e2674fa519003c95a2 index-4209.fits
1e4e04320b7a188b6a8618060096d52b index-4210.fits
a1d1ef557482cf9f9003c74a5c6dad66 index-4211.fits
ae1b8ea7628ffe109f3595ea566c4f6f index-4212.fits
2573d536f83596ebaf58ea4d30091e1b index-4213.fits
befdfa0ccf520f0113d54fe88a2721aa index-4214.fits
2ffdbb967d94ea7677bbf61cf126727b index-4215.fits
6aa8013950d0f69416c29b0e1f6678b3 index-4216.fits
28877a3da074f948ceaec51e83231aa3 index-4217.fits
4505d4005f19bdb6ca71fb3bb52e6adf index-4218.fits
4346ea1a93d9c39bdc07de8abdde4915 index-4219.fits
