When I connect to my QSI 683 you can hear the fan start to run to cool it down but under the CCD temp it shows the temp as NA or 0 (restarted a few times) and fan as 0%. When I take a test image, the image will not display after downloading. I tried another program and it shows the fan %,temp and will download the image. I have used this camera and SGP many times and am not sure what it happening. Also get some jnow/j2000 error (see log)
I have the same camera but I have not seen this one before. Did you change something. It is easy enough to re-install the programs and see if that fixes things. The other thing to try is check or swap over USB cables. Every month or so, I pull out and and pop back all my USB cables in my obsy to keep the contacts clean.
I am able to reproduce it. It appears to only happen if the mount is connected to SGP. Cant understand why this is the case since the mount software has not been touched in months.
I reinstalled stargo software (mount driver) and all was fixed.
